Time is not synchronized between UCCX and cisco IP Phone
radavid20
I want to ask what are the reason/s why time is not synchronized between UCCX server and cisco phone? Is it because of the delay or RTO connection between the server/client? or are there any reasons?
Thanks and regards,
Rona
11 Replies 11
anchoudh
Level 9
Level 9
HI Rona,
Are you referring to the 3 seconds mismatch between the Agent Phone and CAD ? What version of UCCX ?
Anand
Pls rate helpful posts !!
Hi Anchoudh,
The interval time between agent phone and uccx server is around 20 seconds. The resolution that we always did is to type the following commands in cmd prompt of UCCX server (ntpdate ).
The UCCX version is 7.
Thanks and regards,
Rona
HI Rona,
Could you please try the below workaround mentioned in the below link,
http://www.cisco.com/en/US/products/sw/custcosw/ps1846/products_tech_note09186a0080b03125.shtml
Hope this helps.
Anand
Please rate helpful posts by clicking on the stars below the right answers !!
Thats what i did awhile ago. But what is the reason why the time is not synchronized?
Thanks and regards,
Rona
Hi Rona,
What about CUCM time settings?
May be try restarting the NTP server, UCCX box, CAD client box once and see if it helps.
Anand
Hi anchoudh,
The time is already synchronize by doing those methods. Though the time is already recognized, i want to know what are the possible reason/s why the time is not synchronized?
Hope you can help me with this.
Rona
Hi Rona,
I am not sure about the exact parameters which affects this delay, but got the below link which might be of some help here.
http://www.endruntechnologies.com/stratum1.htm
Anand
Hi anchoudh,
Thanks for the link.
Thanks and regards,
Rona
Hi anchoudh,
Another question, what is the accepted time interval between UCCX and IP Phone?
Thanks and regards,
Rona
Hi Rona,
Usually the time between the Phone and the desktop are in synchronization. I have seen in one of the specific release (not remember that version specifically though) where there was a 3 seconds of delay (may be due to some defect, don't know the defect ID either), which got sorted out after upgrading it to the latest SR.
Anand
Thanks anchoudh.
Rona
