UCCE Script Editor Custom Function formula help
Nathan Luk
Level 7
Level 7
Hi guys,
I was wondering if there are any formula gurus who can help me out, I'm trying to create 4 different functions, one takes an enterprise skill group and returns the minimum expected delay / expected wait time. The other 3 are meant to take 2, 3 and 4 different enterprise skill groups and return which of them has the minimum expected delay (this is being used in a pre-routing type scenario to determine where to translation route the call to in order to minimize needing to have the call answered in a different PG from where it's queued). I have the formulas worked out for comparing 2 and 3 different values and figuring out which is lowest but the formula for returning the lowest out of 4 values is doing my head in, hoping that someone has done this before or is an actual developer who nested if statements doesn't do their head in unlike me!:
ESG_MED Function - 1 parameter - Takes Enterprise Skill Group (ESG) Name and returns Minimum Expected Delay (MED):
ValidValue(((EntSkill.Default\%1%.CallsQueuedNow+1)
                                    (ValidValue(EntSkill.Default\%1%.AvgHandledCallsTimeTo5,20))
                                    /max(
                                    EntSkill.Default\%1%.Ready,
                                    (EntSkill.Default\%1%.TalkingIn
                                    EntSkill.Default\%1%.TalkingOut
                                    EntSkill.Default\%1%.TalkingOther))
                                    ),100)
ESG_MED_2 Function - 2 parameters - Takes 2 Enterprise Skill Groups and returns which ESG has the lowest MED (1 for first parameter or 2 for second parameter, also returns 0 if MED across all ESGs=0):
If(ESG_MED(%1%)+ESG_MED(%2%)=0,0,if(ESG_MED(%1%)>ESG_MED(%2%),2,1))
ESG_MED_3 Function - 3 parameters - Same as the previous except takes 3 ESGs:
if(ESG_MED(%1%)+ESG_MED(%2%)+ESG_MED(%3%)=0,0,if(ESG_MED(%1%)< ESG_MED(%2%),if(ESG_MED(%1%)< ESG_MED(%3%),1,3),if(ESG_MED(%1%)< ESG_MED(%3%),2,if(ESG_MED(%2%)< ESG_MED(%3%),2,3))))
ESG_MED_4 Function - 4 parameters - Same as the previous except takes 4 ESGs:
Your help is much appreciated!
Cheers,
Nathan
Nathan,
It seems to me it may be simpler to bring in some ANDs (&&) so that you don't confuse yourself with too many IF statements. Here's everything with some whitespace for clarity:
if(ESG_MED(%1%)+ESG_MED(%2%)+ESG_MED(%3%)+ESG_MED(%4%)=0,0,
if(ESG_MED(%1%)<ESG_MED(%2%)&&ESG_MED(%1%)<ESG_MED(%3%)&&ESG_MED(%1%)<ESG_MED(%4%),1,
if(ESG_MED(%2%)< ESG_MED(%3%)&&ESG_MED(%2%)<ESG_MED(%4%),2,
if(ESG_MED(%3%)< ESG_MED(%4%),3,4))))
And here's the compacted version:
if(ESG_MED(%1%)+ESG_MED(%2%)+ESG_MED(%3%)+ESG_MED(%4%)=0,0,if(ESG_MED(%1%)<ESG_MED(%2%)&&ESG_MED(%1%)<ESG_MED(%3%)&&ESG_MED(%1%)<ESG_MED(%4%),1,if(ESG_MED(%2%)<ESG_MED(%3%)&&ESG_MED(%2%)<ESG_MED(%4%),2,if(ESG_MED(%3%)<ESG_MED(%4%),3,4))))
Your ESG_MED_3 function could be similarly simplified:
if(ESG_MED(%1%)+ESG_MED(%2%)+ESG_MED(%3%)=0,0,if(ESG_MED(%1%)<ESG_MED(%2%)&&ESG_MED(%1%)<ESG_MED(%3%),1,if(ESG_MED(%2%)<ESG_MED(%3%),2,3,4)))
-Jameson
-Jameson
Nathan,
-Jameson
-Jameson
Awesome, thanks very much for that Jameson, it appears Script Editor also has a limit of the number of functions you can use within a custom function and was saying the function exceeded that so I had to expand the ESG_MED functions within the formula out into the full formula making it horrifically long but it looks like it works, thanks for your help!
