UCCX 11.6 Agent-based Predictive outbound problem
AHMED Ali
hello
i have UCCX11.6
we are trying to config an Agent-based Predictive outbound dialer, but when we upload the contacts
no thing is happen
we configured ivr-based Predictive outbound dialer, and it worked fine
but the agent based doesn't  work
all dial-peer has been configured correctly
Ratheesh Kumar
Hi there
Could you double check the configuration with the attached config guide. Mainly the dial-peer section.
https://www.cisco.com/c/en/us/support/docs/customer-collaboration/unified-contact-center-express/116084-trouble-ivr-dialer-00.pdf
For agent based, its the same config except in dial-peer you have to change the outbound voip dial-peer to agent's DN destination pattern/wild card.
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
