UCCX 8.5 recordings are silent.....
Kid Dynamite
We have an issue with using the supervisor software to monitor calls... it records silence. The size of the file it outputs is correct but it is completely blank.
  • The users are using Windows XP machines and I have checked that the QOS RSVP service on WIndows XP is enabled.
  • I did the "netstat" command and could see that the port is not being blocked.
  • postinstall.exe show that it is pointing to the correct server.
It seems to be all set up correctly to a degree as this previously did work but it all of a sudden stopped working one day...... and also, it IS actually recording something... silence!
Suggestions on things to check?
15 Replies 15
I am also facing the same issue - https://supportforums.cisco.com/message/3851009#3851009
Thank you.
Joseph Chirayath
