05-05-2014 11:41 PM - last edited on 03-25-2019 07:25 PM by ciscomoderator
Hello, we have delpoyed UCCX 9.0 and have a question - what type and number of licenses for UCCX do I need for ASR/TTS integration with MRCP server (from SpeechPro company - VoiceNavigator)?
Do we need to upgrade license to Premium?
Solved! Go to Solution.
05-06-2014 02:09 AM
not sure about the agent licenses, but I don't think it's enough - in fact, you need to sort of switch the whole server from Standard or Enhanced to Premium.
Cisco used to sell ASR/TTS products directly but they don't do that anymore, so the only option is to go to Nuance directly and buy it from them. Please double check the SRND and the BOM to see the supported Nuance ASR/TTS versions for your UCCX.
G.
05-06-2014 01:10 AM
unfortunately, "VoiceNavigator" is not supported with UCCX.
You might want to take a look at the UCCX 9 SRND to get all the details.
And yes, Premium license is required to have MRCP-enabled ASR/TTS with UCCX.
G.
05-06-2014 01:57 AM
It is implemented the same as Nuance server.
Speaking about Nuance - so we just need to buy Premium UCCX Agent (concurrent inbound voice seat) licenses from Cisco or resellers, and Nuance ASR/TTS Server licences from Nuance Communications Inc. directly?
05-06-2014 02:09 AM
G.
