UCCX dead time ring problem
Eng.AymanSabry
Dear All
Please i have an issue with my incoming calls
my script is written to write all call info (Time, Date, Called number, Calling number and Agent Extension)
for that in the option connect i set to NO so it can wait till agent reply then DBwrite the correct info
Problem: when calls are placed to the agent (Reserved state) the customer hears complete silence till the agent reply it's like 3-5 sec dead then "Hello this is John, How may i help you?"
Any one can help in this issue
djl
Is the Network Hold Audio Source set correctly in the Call Control Group that is being used for that call?
DJ
djl
DJ
Yes
It worked after adding Media resource list group thanks actually you lead me to the solution
Cool.  Glad the issue is resolved.
DJ
