Using QoS for Vlans
cyndachu002
Hello Everybody i hope you can helpme with something, i have a proyect where i need to put 2 servers and at leats 10 cameras, on a Catalyst 3850, well the datasheet, said this Switch support QoS, but my answer is. How i can configure QoS for every vlan they will be 2 vlan, i want to  take priority for the cameras. Can you suggest my a link or something
sorry mi english isn´t good
i really want that you can help me
Bibin Paul
Please find the below configuration which will help you to achieve the requirement.
The configuration is for your uplink interface.
class-map match-any CAMERA
 match vlan  <Vlan number>
policy-map Parent-Policy
 description <words>
 class CAMERA
  shape average <value>
   service-policy <child policy if any>
Please mark the answer as correct if it helps.
Bibin
Bibin Paul
 description <words>
 class CAMERA
Bibin
thanks for your help bro
it works :)
Chris Deren
Here are useful Cisco docs on QoS design.
http://www.cisco.com/c/en/us/solutions/enterprise/design-zone-application-performance/landing_cVideo.html
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND_40/QoSCampus_40.html
