02-26-2016 12:43 AM - edited 03-01-2019 04:26 AM
Hi Team,
Just wanted to check if APIC EM supports 6807/6500 with SUP 2T as now. If not by what time can we expect the same.
K Subin
02-26-2016 12:46 AM
Hi Subin,
You can see in the release notes: Table 1 - Supported Switches how the 6500 and the 6800 with the Sup2T are supported. Bear in mind of the recommended software version.
APIC-EM release notes:
Carles
02-26-2016 12:58 AM
Hi Carles,
Thanks for the reply i can see 6500 with SUP2T, and for 6800 it is simply written as 6800 series. I hope tit covers both 6880X and 6807 with SUP 2T.
Any idea ??
K Subin
02-26-2016 01:14 AM
Hi Subin,
In the datasheet (table 2) of the platform it is referred as Catalyst 6800 Series Switches, so I believe they are supported.
Datasheet:
regards
Carles
