PnP not working with APIC
Someone1
I have tried to PnP some switches both IE3000 and a C2960X but no luck.
I get them to talk to the APIC EM through DHCP and they start the process but then I get below errors:
2017-03-05 12:54:24 Received fault response from pnp agent for message correlatorId null Response String: XSVC:Client:A required attribute is missing:
2017-03-05 12:54:24 Received fault response from pnp agent for message correlatorId null Response String: XSVC:Client:Badly framed XML received:
2017-03-05 12:54:24 Received new work request from Agent while expecting work response. Retrying operation FILESYSTEM_INFO_REQUESTED
2017-03-05 12:54:24 Device authentication status has changed to Unauthenticated(SUDI feature not supported by device)
2017-03-05 12:53:51 Device first contact
Attaching a small topology and the config I try to push
Versions:
2960x: Version 15.2(2)E3
IE3000: 15.2.4-EA5
/Nils-Oskar
20 Replies 20
Here is the show pnp tech from last try
Switch#show pnp tech-support
hmm, it does not look like it started pnp process at all. Are you sure that you clear the device and everything?
trylvis123
Have you made any progress with this?
I'm experiencing the same issues while trying to deploy to a 2960X switch.
I've tried to deploy through Cisco Prime Infrastructure 3.1.5.I first created a profile, then deployed through "Profile Activation".
The switch seem to successfully connect to the APIC-EM server, but it seem to stop after some initial connection with APIC-EM.
Output from APIC-EM:
10:52:37Received new work request from Agent while expecting work response. Retrying operation FILESYSTEM_INFO_REQUESTED
2017-04-07 10:50:37Received fault response from pnp agent for message correlatorId null Response String: XSVC:Client:A required attribute is missing:
2017-04-07 10:50:36Received fault response from pnp agent for message correlatorId null Response String: XSVC:Client:Badly framed XML received:
2017-04-07 10:50:36Received new work request from Agent while expecting work response. Retrying operation FILESYSTEM_INFO_REQUESTED
2017-04-07 10:48:36Received fault response from pnp agent for message correlatorId null Response String: XSVC:Client:A required attribute is missing:
2017-04-07 10:48:35Received fault response from pnp agent for message correlatorId null Response String: XSVC:Client:Badly framed XML received:
2017-04-07 10:48:35Received new work request from Agent while expecting work response. Retrying operation FILESYSTEM_INFO_REQUESTED
2017-04-07 10:48:35Device authentication status has changed to Unauthenticated(SUDI feature not supported by device)
2017-04-07 10:47:58Device first contact
2017-04-07 10:43:53Reloading of device FCW2XXXXX in progress.
Output from switch:
*Mar 1 00:00:27.615: Read env variable - LICENSE_BOOT_LEVEL =
*Jan 2 00:00:00.150: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module nam e = c2960x_lanbase Next reboot level = lanbase and License = lanbase
Apr 7 08:45:40.114: in Switch 0. Cannot read pid from Flexstack module
Apr 7 08:45:40.212: %HPAA:hpaa_port_bitmap_init:254:n_ports = 52, sizeof (**hpa a_port_bitmap.bitlist_array) = 16
Apr 7 08:46:23.980: %STACKMGR-4-SWITCH_ADDED: Switch 1 has been ADDED to the st ack
Apr 7 08:46:25.402: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, chan ged state to down
Apr 7 08:46:25.402: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEtherne t0, changed state to down
Apr 7 08:46:27.248: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
Apr 7 08:46:49.897: %STACKMGR-5-SWITCH_READY: Switch 1 is READY
Apr 7 08:46:49.897: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has ch anged to state DOWN
Apr 7 08:46:49.897: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has ch anged to state DOWN
Apr 7 08:46:50.415: %STACKMGR-5-MASTER_READY: Master Switch 1 is READY
Apr 7 08:46:50.422: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(2)E6, R ELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Fri 16-Dec-16 21:27 by prod_rel_team
Apr 7 08:46:50.533: %USB_CONSOLE-6-MEDIA_RJ45: Console media-type is RJ45.
Apr 7 08:46:52.354: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to d own
Apr 7 08:46:53.358: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEtherne t0, changed state to down
Apr 7 08:46:55.304: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed sta te to up
Apr 7 08:46:56.308: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthe rnet1/0/1, changed state to up
Apr 7 08:47:23.312: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, chan ged state to up
Apr 7 08:47:27.831: %PNPA-DHCP Op-43 Msg: Process state = READY
Apr 7 08:47:27.831: %PNPA-DHCP Op-43 Msg: OK to process message
Apr 7 08:47:27.831: XML-UPDOWN: PNPA_DHCP_OP43 XML Interface(102) UP. PID=141
Apr 7 08:47:27.831: %PNPA-DHCP Op-43 Msg: _pdoon.1.ntf.don=141
Apr 7 08:47:27.835: %PNPA-DHCP Op-43 Msg: _pdoop.1.org=[A1D;B2;K4;I8.8.8.8; J80]
Apr 7 08:47:27.835: %PNPA-DHCP Op-43 Msg: _pdgfa.1.inp=[B2;K4;I8.8.8.8;J80]
Apr 7 08:47:27.835: %PNPA-DHCP Op-43 Msg: _pdgfa.1.B2.s12=[ ipv4 ]
Apr 7 08:47:27.835: %PNPA-DHCP Op-43 Msg: _pdgfa.1.K4.htp=[ transport http ]
Apr 7 08:47:27.835: %PNPA-DHCP Op-43 Msg: _pdgfa.1.Ix.srv.ip.rm=[ 8.8.8.8 ]
Apr 7 08:47:27.835: %PNPA-DHCP Op-43 Msg: _pdgfa.1.Jx.srv.rt.rm=[ port 80 ]
Apr 7 08:47:27.835: %PNPA-DHCP Op-43 Msg: _pdoop.1.ztp=[pnp-zero-touch] host=[] ipad=[8.8.8.8] port=80
Apr 7 08:47:27.835: %PNPA-DHCP Op-43 Msg: _pors.done=1
Apr 7 08:47:27.835: %PNPA-DHCP Op-43 Msg: _pdokp.1.now=PNPA_DHCP_OP43 pid=141
Apr 7 08:47:27.835: XML-UPDOWN: PNPA_DHCP_OP43 XML Interface(102) SHUTDOWN(101) . PID=141 got vend id vend spec. info ret: succeed
Apr 7 08:47:43.815: AUTOINSTALL: Obtain siaddr 9.9.9.9 (as config server)
Apr 7 08:47:53.822: %PNP-6-HTTP_CONNECTING: PnP Discovery trying to connect to PnP server http://8.8.8.8:80/pnp/HELLO
Apr 7 08:47:54.825: %PNP-6-HTTP_CONNECTED: PnP Discovery connected to PnP serve r http://8.8.8.8:80/pnp/HELLO
Apr 7 08:47:55.839: %PNP-6-PROFILE_CONFIG: PnP Discovery profile pnp-zero-touch configured
%Error opening tftp://9.9.9.9/network-confg (Timed out)
Apr 7 08:48:24.835: %SYS-6-CLOCKUPDATE: System clock has been updated from 08:4 8:20 UTC Fri Apr 7 2017 to 08:48:24 UTC Fri Apr 7 2017, configured from console by console.[OK]
Apr 7 08:48:33.076: %PKI-6-CONFIGAUTOSAVE: Running configuration saved to NVRAM
%Error opening tftp://9.9.9.9/cisconet.cfg (Timed out)
%Error opening tftp://9.9.9.9/router-confg (Timed out)
%Error opening tftp://9.9.9.9/ciscortr.cfg (Timed out)
Where 8.8.8.8 = APIC-EM, and 9.9.9.9 = DHCP-server.
DHCP Option 43 looks like this:
I have not had much time to troubleshoot this but I have a TAC case going.
Had a webex with TAC but they needed to consult some people about this problem and should get back to me.
That was yesterday April 6th.
/Nils-Oskar
Do you have any updates on this issue? Did you or TAC find an explaination or workaround?
Do you know what was the problem? I have a similar issue with C3560CX.
Thank you for your reply!
