Provisioning a 3802i through PnP with Prime Infrastructure 3.1 / APIC-EM 1.4.2
rquist
Hi ,
I am trying to PnP provision a new 3802i AP (which I upgraded from 8.2 to 8.3 release in order to get PnP to function) with PI3.1.6 integrated with APIC-EM 1.4.2 with a new config. For some reason it's not properly getting through and stopping the process with an error. I cannot find any reference to the error. The json file which was generated looks perfectly fine to me. Is anyone having a clue on what the issue is?
TimestampEvent
2017-05-08 16:22:25 (W. Europe Standard Time)Received response from pnp agent for message correlatorId: Cisco-PnP-1.0-6-f21818bf-c94d-4g9d-9db7-73fe5453aef4-1 but with error code : ZTD_CMD_ERROR Response String: XSVC_ERROR:XSVC_ERROR_CONFIG_UPGRADE_INTERNAL:PnP - Config Apply failed. Invalid value in json or missing Primary WLC IP service log: null
2017-05-08 16:22:21 (W. Europe Standard Time)Hostname configured successfully
2017-05-08 16:22:20 (W. Europe Standard Time)Matched a pre-provisioned rule in site Test
2017-05-08 16:22:14 (W. Europe Standard Time)AP IP address successfully retrieved: 10.1.20.102
2017-05-08 16:18:59 (W. Europe Standard Time)Device first contact
Next I was expecting also to be able to set a FlexConnect Group as mentioned here Cisco Prime Infrastructure 3.1 User Guide - Configuring Plug and Play [Cisco Prime Infrastructure] - Cisco under Plug and Play profiles. But it seems not be be in the Prime GUI yet.
thanks,
Richard
aradford
can you share the json file you are using.  Please x.x.x.x the ip address, but i want to see the structure.
here it is, so this is how it has been injected from Prime Infra, but I also tried from APIC-EM directly - same result.
{"primaryWlcIP":"x.x.x.x","primaryWlcName":"xxxx","secondaryWlcIP":"y.y.y.y","secondaryWlcName":"yyyy","tertiaryWlcIP":"z.z.z.z","tertiaryWlcName":"zzzz","apGroup":"APG_Test","apMode":"FlexConnect"}
just a quick thought.  You are not falling victim to Microsoft smart quotes?
the above looks fine, but i have seen the smart quotes issue many times in the past.
Change curly quotes to straight quotes and vice versa - Office Support
