on 06-14-2017 11:40 PM - edited on 03-25-2019 01:19 PM by ciscomoderator
This is an example of service reconciliation code for the NSO mpls-vpn demo from a bottom-up perspective. The idea is that a service is configured in the network and NSO would need to discover and reconciliate it.
NSO min version: 4.4
The reconciliation logic is located here: https://github.com/NSO-developer/Cisco-NSO-MPLS-VPN-service-reconciliation-example/blob/master/packages/l3vpn/python/action.py
To run it:
Now we will simulate a service that was configured in the network and is not know by NSO. We will do that by deleting the service in NSO with the "no-networking" option.
rogaglia$ ncs_cli -C -u admin
admin@ncs# config
admin@ncs(config)# no vpn l3vpn volvo
admin@ncs(config)# commit no-networking
Commit complete.
admin@ncs(config)#You will see now that a number of devices are "out-of-sync":
admin@ncs(config)# devices check-syncYou can see that the service config is in the devices via checking the compare config output in the different devices:
admin@ncs(config)# devices device * compare-config
Now we can run the reconciliation code to discover service. We will first run it as "dry-run", which means that we want to check what changes would be sent to the devices if the discovered services would be commited:
admin@ncs(config)# vpn l3vpn-service-discovery dry-run
status false
message Commit Dry Run Device Changes:
Device: pe0
route-policy volvo
pass
end-policy
!Commit Dry Run Service Changes:
Operation: MOP_CREATED - KeyPath: /l3vpn:vpn/l3vpn{volvo} - Old Value: None - New Value: None
Operation: MOP_VALUE_SET - KeyPath: /l3vpn:vpn/l3vpn{volvo}/name - Old Value: None - New Value: volvo
Operation: MOP_VALUE_SET - KeyPath: /l3vpn:vpn/l3vpn{volvo}/private/re-deploy-counter - Old Value: None - New Value: 0
Operation: MOP_CREATED - KeyPath: /l3vpn:vpn/l3vpn{volvo}/endpoint{discovered_ce0} - Old Value: None - New Value: None
Operation: MOP_VALUE_SET - KeyPath: /l3vpn:vpn/l3vpn{volvo}/endpoint{discovered_ce0}/id - Old Value: None - New Value: discovered_ce0
Operation: MOP_VALUE_SET - KeyPath: /l3vpn:vpn/l3vpn{volvo}/endpoint{discovered_ce0}/bandwidth - Old Value: None - New Value: 6000000
Operation: MOP_VALUE_SET - KeyPath: /l3vpn:vpn/l3vpn{volvo}/endpoint{discovered_ce0}/ce-interface - Old Value: None - New Value: GigabitEthernet0/11
Operation: MOP_VALUE_SET - KeyPath: /l3vpn:vpn/l3vpn{volvo}/endpoint{discovered_ce0}/as-number - Old Value: None - New Value: 65003
Operation: MOP_VALUE_SET - KeyPath: /l3vpn:vpn/l3vpn{volvo}/endpoint{discovered_ce0}/ip-network - Old Value: None - New Value: 10.10.1.0/24
Operation: MOP_VALUE_SET - KeyPath: /l3vpn:vpn/l3vpn{volvo}/endpoint{discovered_ce0}/ce-device - Old Value: None - New Value: ce0
Operation: MOP_CREATED - KeyPath: /l3vpn:vpn/l3vpn{volvo}/endpoint{discovered_ce1} - Old Value: None - New Value: None
Operation: MOP_VALUE_SET - KeyPath: /l3vpn:vpn/l3vpn{volvo}/endpoint{discovered_ce1}/id - Old Value: None - New Value: discovered_ce1
Operation: MOP_VALUE_SET - KeyPath: /l3vpn:vpn/l3vpn{volvo}/endpoint{discovered_ce1}/bandwidth - Old Value: None - New Value: 6000000
Operation: MOP_VALUE_SET - KeyPath: /l3vpn:vpn/l3vpn{volvo}/endpoint{discovered_ce1}/ce-interface - Old Value: None - New Value: GigabitEthernet0/11
Operation: MOP_VALUE_SET - KeyPath: /l3vpn:vpn/l3vpn{volvo}/endpoint{discovered_ce1}/as-number - Old Value: None - New Value: 65001
Operation: MOP_VALUE_SET - KeyPath: /l3vpn:vpn/l3vpn{volvo}/endpoint{discovered_ce1}/ip-network - Old Value: None - New Value: 10.7.7.0/24
Operation: MOP_VALUE_SET - KeyPath: /l3vpn:vpn/l3vpn{volvo}/endpoint{discovered_ce1}/ce-device - Old Value: None - New Value: ce1
Operation: MOP_CREATED - KeyPath: /l3vpn:vpn/l3vpn{volvo}/endpoint{discovered_ce4} - Old Value: None - New Value: None
Operation: MOP_VALUE_SET - KeyPath: /l3vpn:vpn/l3vpn{volvo}/endpoint{discovered_ce4}/id - Old Value: None - New Value: discovered_ce4
Operation: MOP_VALUE_SET - KeyPath: /l3vpn:vpn/l3vpn{volvo}/endpoint{discovered_ce4}/bandwidth - Old Value: None - New Value: 6000000
Operation: MOP_VALUE_SET - KeyPath: /l3vpn:vpn/l3vpn{volvo}/endpoint{discovered_ce4}/ce-interface - Old Value: None - New Value: GigabitEthernet0/18
Operation: MOP_VALUE_SET - KeyPath: /l3vpn:vpn/l3vpn{volvo}/endpoint{discovered_ce4}/as-number - Old Value: None - New Value: 65002
Operation: MOP_VALUE_SET - KeyPath: /l3vpn:vpn/l3vpn{volvo}/endpoint{discovered_ce4}/ip-network - Old Value: None - New Value: 10.8.8.0/24
Operation: MOP_VALUE_SET - KeyPath: /l3vpn:vpn/l3vpn{volvo}/endpoint{discovered_ce4}/ce-device - Old Value: None - New Value: ce4
Operation: MOP_VALUE_SET - KeyPath: /l3vpn:vpn/l3vpn{volvo}/route-distinguisher - Old Value: None - New Value: 12345
admin@ncs(config)# Let's take attention to this part of the dry-run output:status false
Device: pe0
route-policy volvo
pass
end-policy
!The commit of the discovered service should not move forward as it would mean a change in the device config. Note: this behaviour was expressly done by introducing a NED missfunction.The rest of the text output shows the values of the services that were discovered.
status true
No Changes (text omitted)We can see that now the status is set to "true" and we can move forward with the reconciliation:
System message at 2017-06-08 00:43:13...
Commit performed by admin via tcp using .
admin@ncs(config)#
Link to repository: GitHub - NSO-developer/Cisco-NSO-MPLS-VPN-service-reconciliation-example
To prevent pushing discovered service to the device, you could probably change apply() in your code to something like apply(True, _ncs.maapi.COMMIT_NCS_NO_NETWORKING) ?
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
