1000base-LH, Part number--SFCT-5716PZ-CS1
abeebvm
I have a Nexus-7000 series and having card N7K-M224XP-23L. I am connecting to access switch 3850 and having sfp in both sides. But it is not coming up.
N7K-M224XP-23L is basically 10G SFP card. so will this not support 1G.
Aby
nazimkha
Level 4
Level 4
Its a 10G card will not support 1G SFP
Thanks for your reply. Is there any supporting document.
You can check the Transceiver Module Group (TMG) Compatibility Matrix tool. Just type in the part number and it will show all the SFP compatible with the product. Cisco changed from a document to the tool from 8/2018
https://tmgmatrix.cisco.com/home
Thanks for your prompt reply
