1000v Packet & Control on traditional vSwitch
jconides
I'm deploying the 1000v in a scenario where the Packet & Control VLANs are on a traditional vSwitch and not the 1000v. I'm having difficulty getting the VEM talking to the VSM, and have been advised to set up system VLANs for Packet & Control on an uplink profile. Since the Packet & Control won't be migrated to an uplink profile, is this really necessary?
John
So, if I am understanding you correctly you will have 2 vnmnics for production and 2 for maybe a DMZ? In this case you only need to define the system vlans on one of the uplink port-profiles. Make sure you configure the allowed trunk list properly so that you don't have the same vlans trunked on both uplink port profiles
Jeremy Waldrop
Level 4
Level 4
Yes, the packet and control VLANs have to be allowed on the trunk to the ESX vmnics and on the uplink port profile those have to be configured as system vlans. Here is an example of a configuration where the packet and control VLANs are 611 and 612. In this config the VSM is hosted on a standard vSwitch and the ESX hosts has 2 other dedicated vmnics that are uplinked to the N1KV.
The port groups on the standrad vSwitch are for the VSM to communicate on the management, packet and control VLANs where as the the uplink port-profile is for the hosts to communcate with the VSM over those VLANs. The system vlan config is to tell the N1KV to always bring those up in a forwarding state exempt from any policies.
port-profile type ethernet esx-host-prod-uplinks
  vmware port-group
  switchport mode trunk
  switchport trunk allowed vlan 1-3967,4048-4093
  channel-group auto mode on mac-pinning
  no shutdown
  system vlan 13,611-612
  description Physical Ethernet ESXi Host Uplinks for Prod
  state enabled
svs-domain
  domain id 611
  control vlan 611
  packet vlan 612
  svs mode L2
Thanks for the explanation. The hosts are going to have to uplink profiles, one internal and one external. Do I need to define the system VLANs on both?
John Conides | Solutions Engineer
p 617-304-7577
www.greenpages.com<http://www.greenpages.com/> | Kittery ME | Boston MA
Thanks, I am back onsite on Tuesday and will give this a try!
p 617-304-7577
