1000v SSL Cert Expired
james21970
All,
we are receiving an SSL certificate has expired trap for our 1000v's. We received this for our UCS FI's, and the fix was simple to find, however when doing a similar search for this trap on the 1000v, i've been unable to find any specific information.
I've found this regarding an SSL cert:
http://www.cisco.com/en/US/docs/switches/datacenter/nexus1000/sw/4_0/troubleshooting/configuration/guide/trouble_5modules.html
However, this is stating that there will be no connection to the vCenter server if this cert is the problem, and we show connected.
Any ideas what SSL cert this trap is in relation to, and how can this be fixed?
rclarke2
Cisco Nexus 1000V Security Configuration Guide, Release 4.2(1)SV1(5.1) - Disabling the HTTP Server [Cisco Nexus 1000V Sw…
To change the security certificate for the HTTP server, use the install http-certificate bootflash: <cert_path> command. After executing this command, the Webserver begins using the security certificate. The certificate that is being installed must be a server certificate containing both a public and a private key.
