100G port spilt in to 25X 4
sachinc01
Can you do the 100G split to 4x25G.  (Which cable will be used for that)
We have QSFP-100G-SR4-S transiver.
N9K-C93108TC-FX
Sergiu.Daniluk
Hi @sachinc01
First you need to check if the port is breakable or not:
switch(config)# show interface ethernet 1/X capabilities | grep -i break
If yes, then you can split 100G in 4x 25G. You will need something similar to this type of MPO breakout fiber: https://www.fs.com/de-en/products/68047.html
The command to change the port from 100G to 4x25g is:
switch(config)# interface breakout module 1 port X map 25g-4
 Stay safe,
Sergiu
Thanks sirji thanks for the information.
But customer want to confirm before purchase does this device and Module
support to 100G port split in to 25 X4
I have seen in documents it support but need to verify can you guide on
this please..
Rs,
Sachin
