10-18-2021 11:53 PM - edited 10-19-2021 05:30 AM
I can see every Broadcast Domain has one multicast IP address in our ACI, I am curious to know that where do they get the multicast IP address from? Is it from APIC multicast POOL?
I dont see any multicast pool configured in Fabric Access Policies.
Solved! Go to Solution.
10-19-2021 01:03 AM
Hi @Xdxb
When you perform the initial setup of the APIC, you are asked for "IP address pool for bridge domain multicast address (GIPo)"
GIPo stands for Group IP outer address.
The multicast IP addresses for both BDs and VRFs are allocated from this pool, and will be used to forward BUM traffic within ACI fabric and also between Pods in a Multi-Pod Setup.
In case you are curious when VRF GIPo is used, the answer is simple - only for user multicast traffic when you have PIM enabled on the BD. Here is a table to visualize the options:
Traffic |
Non-MC Routing-enabled BD |
Broadcast |
BD GIPo |
BD GIPo |
Unknown Unicast Flood |
BD GIPo |
BD GIPo |
Multicast |
BD GIPo |
VRF GIPo |
If you want to find more details of the GIPo specific to your fabric you can use these commands:
1. Find the GIPo range configured during initial APIC setup:
apic# cat /data/data_admin/sam_exported.config Setup for Active and Standby APIC <snip> GIPo = 225.0.0.0/15 </snip>
2. Find multicast IP address for a specific BD:
apic# moquery -c fvBD -f 'fv.BD.name=="BD1"' <snip>
bcastP : 225.1.91.128
</snip>
3. Find the VRF GIPo (will return data only if you have PIM enabled on VRF level):
apic# moquery -c pimCtxP
<snip> vrfGipo : 225.1.192.0/3
</snip>
Stay safe,
Sergiu
10-19-2021 01:03 AM
Hi @Xdxb
Traffic |
Broadcast |
BD GIPo |
BD GIPo |
BD GIPo |
BD GIPo |
Multicast |
BD GIPo |
VRF GIPo |
</snip>
</snip>
Stay safe,
Sergiu
