BGP feature on Nexus 7710
Hello all,
I have a quick question regarding BGP routing protocol. In our DataCenter we have Nexus7710 version 8.3(2), with N77-F348XP-23 line cards, and we are currently running OSPF. We would like to enable the BGP feature, in order to create BGP peerings with our NSX environment. I enabled the feature on one of our VDCs, but I haven't configured the protocol yet.
From an old discussion with some peers, I was under the impression that BGP is only supported when using M3 line cards (which seemed weird at the time, since BGP it is a routing protocol... why should the line cards have anything to do with this), or does this limitation only apply to MP-BGP EVPN?
Can someone help clarify? Can I use BGP routing protocol regardless of line cards? If the feature can be enabled, can I use it?
Thank you in advance,
Katerina
Dawei
Yes, I am not sure where you saw this statement, but BGP is a software protocol and should not be related to the type of linecard.
Dawei
Thank you so much for the answer.
It did strike me as really odd, so that is why I wanted to clarify! In such a case I will proceed to configure it as intended!
Thanks!
