Cisco 93128TX Transceiver issues (40G to 10G)
Mary Ghabrai
For Cisco 93128TX switches, we bought CVR-QSFP-SFP10G adapters and SFP-10G-SR (FS brand)
on the vendor's page, it says that the adapter supports SFP-10G-SR. but I couldn't get the interface to come up. below is a summary of the issue and what's been set up. Has anyone encountered this issue?
- I have enabled "service unsupported-transciever"
- on the 40G ports, I have configured "speed-group 10000" according to this forum
- when I do a show interface, I have this error: "Transceiver speed does not match the speed configured on the port"
- configuration on the port :
interface Ethernet2/1
speed-group 10000
no shutdown
11 Replies 11
Sergiu.Daniluk
Hi @Mary Ghabrai
Can you share the following outputs from your device, while the QSA + SFP are inserted:
show module
show run int eth2/1 all
show interface eth2/1
show interface eth2/1 status
show interface eth2/1 capabilities
show interface eth2/1 transceiver details
Note: Make sure you remove the SNs from the outputs, to avoid disclosing sensitive data about your devices.
Cheers,
Sergiu
So I upgraded the switches from 7.0(3)I7(8) to version 9.3(4) and the error went away but the links won't come up. show command results below:
ELG-COR-0002# show module
Mod Ports Module-Type Model Status
1 96 1/10G-T Ethernet Module N9K-C93128TX active *
2 8 40G Ethernet Expansion Module N9K-M12PQ ok
Mod Sw Hw Slot
1 9.3(4) 2.0 NA
2 NA 1.1 GEM
Mod MAC-Address(es) Serial-Num
1 50-87-89-a2-3c-78 to 50-87-89-a2-3c-df SAL********
2 88-f0-31-bd-41-be to 88-f0-31-bd-41-c9 SAL********
Mod Online Diag Status
1 Pass
2 Pass
ELG-COR-0002# show run int eth2/1 all
!Command: show running-config interface Ethernet2/1 all
!Running configuration last done at: Thu Apr 30 16:08:56 2020
!Time: Thu Apr 30 18:57:47 2020
version 9.3(4) Bios:version 07.67
no description
lacp port-priority 32768
lacp rate normal
cdp enable
switchport
switchport mode access
no switchport monitor
no switchport dot1q ethertype
no switchport priority extend
switchport access vlan 1
switchport trunk native vlan 1
no switchport vlan mapping enable
priority-flow-control mode auto
priority-flow-control watch-dog-interval off
spanning-tree port-priority 128
spanning-tree cost auto
spanning-tree link-type auto
no spanning-tree bpduguard
no spanning-tree bpdufilter
flowcontrol receive off
flowcontrol send off
delay 1
snmp trap link-status
mtu 1500
link debounce time 100
no beacon
no link transmit reset-skip
link mac-up timer 0
speed-group 10000
speed auto
duplex auto
fec auto
link dfe adaptive-tuning
negotiate auto
logging event port link-status default
logging event port trunk-status default
storm-control broadcast level 100.00
storm-control multicast level 100.00
storm-control unicast level 100.00
no storm-control action
bandwidth 40000000
no bandwidth inherit
load-interval counter 1 30
load-interval counter 2 300
no load-interval counter 3
no switchport block multicast
no switchport block unicast
no switchport mac-learn disable
no shutdown lan
no udld disable
no switchport autostate exclude
no shutdown
ELG-COR-0002# show interface eth2/1
Ethernet2/1 is down (Link not connected)
admin state is up, Dedicated Interface
Hardware: 10000/40000 Ethernet, address: 88f0.31bd.41be (bia 88f0.31bd.41be)
MTU 1500 bytes, BW 40000000 Kbit , DLY 10 usec
Encapsulation ARPA, medium is broadcast
Port mode is access
auto-duplex, auto-speed, media type is 40g
Beacon is turned off
Auto-Negotiation is turned on FEC mode is Auto
Input flow-control is off, output flow-control is off
Auto-mdix is turned off
Rate mode is dedicated
Switchport monitor is off
EtherType is 0x8100
EEE (efficient-ethernet) : n/a
admin fec state is auto, oper fec state is off
Last link flapped never
0 interface resets
Load-Interval #1: 30 seconds
30 seconds input rate 0 bits/sec, 0 packets/sec
30 seconds output rate 0 bits/sec, 0 packets/sec
input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
Load-Interval #2: 5 minute (300 seconds)
300 seconds input rate 0 bits/sec, 0 packets/sec
300 seconds output rate 0 bits/sec, 0 packets/sec
RX
0 unicast packets 0 multicast packets 0 broadcast packets
0 input packets 0 bytes
0 jumbo packets 0 storm suppression packets
0 runts 0 giants 0 CRC 0 no buffer
0 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
0 output packets 0 bytes
0 jumbo packets
0 output error 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 0 output discard
0 Tx pause
ELG-COR-0002# show interface eth2/1 status
Port Name Status Vlan Duplex Speed Type
Eth2/1 -- notconnec 1 auto auto --
ELG-COR-0002# show interface eth2/1 capabilities
Ethernet2/1
Model: N9K-C93128TX
Type (SFP capable): unknown
Speed: 10000,40000
Duplex: full
Trunk encap. type: 802.1Q
Channel: yes
Broadcast suppression: percentage(0-100)
Flowcontrol: rx-(off/on),tx-(off/on)
Rate mode: dedicated
Port mode: Routed,Switched
QOS scheduling: rx-(none),tx-(4q)
CoS rewrite: yes
ToS rewrite: yes
SPAN: yes
UDLD: yes
MDIX: no
TDR capable: no
Link Debounce: yes
Link Debounce Time: yes
FEX Fabric: no
dot1Q-tunnel mode: no
Pvlan Trunk capable: yes
Port Group Members: 97-102
EEE (efficient-eth): no
PFC capable: yes
Buffer Boost capable: no
Speed group capable: yes
Breakout capable: no
MACSEC capable: no
ELG-COR-0002# show interface eth2/1 transceiver details
Ethernet2/1
transceiver is not supported
SFP Detail Diagnostics Information (internal calibration)
Current Alarms Warnings
Measurement High Low High Low
Temperature N/A N/A N/A N/A N/A
Voltage N/A N/A N/A N/A N/A
Current N/A N/A N/A N/A N/A
Tx Power N/A N/A N/A N/A N/A
Rx Power N/A N/A N/A N/A N/A
Transmit Fault Count = 0
Note: ++ high-alarm; + high-warning; -- low-alarm; - low-warning
*** This QSFP support partial diagnostic data! ***
Hello @Mary Ghabrai
Have you tried configuring "speed 10000" on the interface?  It looks like your interface is still in auto (40G).
Cheers,
Sergiu
yes I've tried that. below is the error I get: (I've also tried to remove the auto-negotiation but I get this error: "ERROR: cannot turn off auto-negotiate with speed auto")
Hello Mary
As stated previously the M6PQ module isn't 10gb supported according to cisco transceiver matrix, So can you confirm what module you have procured?  M6PQ_E does support 10GB
Try defaulting the interface on both sides of the interconnect and then disable negotiation and specify the speed/duplex
default interface x/x
speed 10000
no negotiate auto
Kind Regards
Paul
we have M12PQ
Hi @Mary Ghabrai
So, based on the transceiver matrix, the N9K-M12PQ supports CVR+ SFP-10G.
Are the CVR and SFP you are using both cisco SFPs?
Have you tried with other SFP/CVR? What is the result?
Have you tried the current CVR/SFP in other ports? What is the result?
Have you tried the current CVR/SFP in other switch? What is the result?
Sergiu
Hi Sergiu,
- Are the CVR and SFP you are using both cisco SFPs? No, they're the FX brand (unfortunatley I'm remote and didn't have access and budget to test a Cisco optic
- Have you tried with other SFP/CVR? What is the result? yes the current optics are the FS brand and it doesn't work
- Have you tried the current CVR/SFP in other ports? What is the result? yes, none work
- Have you tried the current CVR/SFP in other switch? What is the result? yes, I'm testing this on 4 switches and they all have the same issue
Yep. Kinda looks like SFPs to be the problem here. Have you enabled "service unsupported-transceiver"? This might help. However, important note: if you experience an issue with a non-Cisco SFP, and the fault or defect can be traced to the use of third-party transceivers, then the Cisco support team will simply tell you to use Cisco SFP.
Cheers,
Sergiu
Hello
I cannot see that M6PQ module for10gb being supported for that switch on the capabiltiy matrix? - here
Kind Regards
Paul
Hi @paul driver
Nexus 93128TX is using M6PQ, M6PQ-E, or M12PQ modules to have 40G ports. So in the matrix you need to look at the modules and not at the Nexus9000 as a platform:  https://tmgmatrix.cisco.com/?tpid=73&npid=137&npid=139
As you can see, it is supported with a note:
Cheers,
Sergiu
