Nexus 9396TX 6 x 40 G module speed configuration
Amr Hafez
Hi All
I bought 4 N9396TX with N9K-M6PQ module that support 6 port 40 G with QSFP-40G-SR-BD
I want to change the speed of module port from 40 G to 10 G and insert the CVR-QSFP-10GSFP converter to pysical convert from 40 G to 10 G and install SFP+ SR and LR in the converter
so I follow the following steps:
1- after power up the NX SW, I installed the converter with SFP+ in both sidesand it worked and up without any additional configuration
2- then I tried to insert the QSFP 40 G beside the SFP+ 10 G and I tried to shut and no shut the 40 G interface to enable it but I found that the 10 G SFP+ shut down, so I removed the 40 G QSFP and reset all ports to defult using
     #default interface ethernet 2/1-6
but still not worked and tried to use the CLI command under the used interface
    #interface ethernet 2/1
    #speed-group 10000
then an error message appeared  "ERROR: Ethernet1/40: Configuration does not match the port capability"
but the show interface ethernet 2/1 shoed that the speed became 10G but the port still down
so I searched and found that I must disable auto negotiate using
    #no negotiate auto
but the command also refused also
I Know that the module port can work all in 10 G or all in 40 G so I removed the 40 G QSFP
does the module need to be restarted ?
and any suggestion?
Amr Hafez
I found the answer here:
Cisco QSFP+ to SFP+ Adapter Module Support
The Cisco QSFP+ to SFP+ Adapter (QSA) module provides 10G support for the 40G uplink ports that are a part of the Cisco Nexus M6PQ and Cisco Nexus M12PQ uplink modules of specific Cisco Nexus 9300 devices described below.
A group of six consecutive ports in the M6PQ or M12PQ uplink module must be operating at the same speed (40G or 10G) to use the QSA/QSFP modules.
  • For Cisco Nexus 9396PX devices, 2/1-6 ports form the first port speed group and the remaining 2/7-12 ports form the second port speed group.
  • For Cisco Nexus 93128PX/TX devices, 2/1-6 ports form the first port speed group and the remaining 2/7-8 ports form the second port speed group.
  • For Cisco Nexus 937xPX/TX devices, 1/49 - 54 ports form the only port speed group.
Use the speed-group 10000 command to configure the first port of a port speed group for the QSA. This command specifies the administrator speed preference for the port group. (The default port speed is 40G.)
  • The speed-group 10000 command specifies a speed of 10G.
  • The no speed-group 10000 command specifies a speed of 40G.
After the speed has been configured, the compatible transceiver modules are enabled. The remaining transceiver modules in the port group (incompatible transceiver modules) become error disabled with a reason of "check speed-group config".
The Cisco QSFP+ to SFP+ Adapter (QSA) module does not provide 10G support for the 40G line cards for Cisco Nexus 9500 devices.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/6-x/interfaces/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_chapter_010.html
thank you!
