06-21-2021 05:21 AM
I have a newly connected cisco 9500, our network monitoring system is showing the below alerts.
The switch ring and the power supply's appear to be ok.
9500, Data Center Networking
Can you provide a few commands which I can run which would confirm these are false alerts?
Stack Ring - Redundant false
Switch 2 Power Supply Module 0 on (fan failed)
Switch 2 Power Supply Module 0 normal
Switch 2 Power Supply Module 1 on (fan failed)
Switch 2 Power Supply Module 1 normal
Switch 1 Power Supply Module 0 on
Switch 1 Power Supply Module 0 normal
Switch 1 Power Supply Module 1 on
Switch 1 Power Supply Module 1 normal
Solved! Go to Solution.
06-27-2021 10:52 PM
Hi @Jag187
You are on the wrong subcommunity. Try to move the question to switching category.
Cheers,
Sergiu
06-27-2021 10:52 PM
Hi @Jag187
Cheers,
Sergiu
