Cisco 9K Nexus/FEX Connectivity
jamesupcott1
Hi All
I am currently looking to dual connect a new FEX unit (C93108TC), to two separate head units (C93180YC) to achieve resilience.
I have currently connected the first head unit to the FEX which has worked fine, however I want to confirm requirements for connectivity to the other C93180YC head unit. Is VPC essential to achieve this, or can I achieve the required connectivity without utilising VPC?
If VPC is an essential requirement, can you advise how the port-channel should be configured from both head units to the FEX? I currently have Portchannel 101 configured between the single head unit and the FEX. Essentially how do I scale this out to the other head unit?
Kind Regards
James
0 Replies 0
