Cisco Nexus 3048 password recovery
beta_admin66
On the Cisco Nexus Switch 3048, I did a password recovery. I have assigned a new password, then loaded the bootflash and then the following error messages have occurred and the password after login was also not accepted. What could be the mistake?
switch(boot)# load bootflash:nxos.7.0.3.I4.8a.bin
/etc/rc.d/rcS.d/S99load-isan: line 50: [: ff: integer expression expected
/etc/rc.d/rcS.d/S99load-isan: line 58: [: ff: integer expression expected
Loading System Software Tue Feb 16 12:40:00 UTC 2010
INIT: Switching to runlevel: 3
INIT: Sending processes the TERM signal
INIT: (boot)#
Mounting other filesystems: [ OK ]
INIT: c
INIT: cannot execute "/isan/bin/sysmgr_spawn"
INIT: cannot execute "/isan/bin/libvirtd.sh"
INIT: Id "libv" respawning too fast: disabled for 5 minutes
INIT: Id "sm" respawning too fast: disabled for 5 minutes
ERROR: ld.so: object '/isan/lib/libnxoscustom.so' from LD_PRELOAD cannot be preloaded: ignored.
User Access Verification
(none) login: admin
Password:
Login incorrect
(none) login:
(none) login:
(none) login:
(none) login: admin
Password:
Login incorrect
(none) login: admin
Password:
Login incorrect
(none) login:
David Castro F.
I hope you are doing great, have you been following the steps of this document:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/password_recovery/b_nx_os_pwr/nx_os_pw.html
In the following post there was some issues trying to get it working:
https://community.cisco.com/t5/storage-networking/need-help-with-nexus-3000-password-recovery/td-p/2347328
You could try uploading the same image instead of using the one in the flash or using another image.
Keep me posted,
Please rate all helpful posts,
David Castro,
Hello David,
What is the significance of this message:
Password:
Is the admin-password that I was created in the boot Modus on the switch the same at the Login Password?
Thank you very much
