Cisco Nexus 5010/5020 - Virtual port channel
beta_admin66
Hello together,
I would like to connect a Cisco Nexus 5010 to a Cisco 5020 with port channel and vpc.
I set up channel-group xx mode active on the Cisco Nexus 5010 ethernet interfaces and on the Cisco Nexus 5020 on the Ethernet interfaces channel-group xx mode passive.
at the command show vpc I get the output that the port channel are down. Can I connect only one Cisco Nexus 5010 to a Cisco Nexus 5010 via a port-channel/vpc?
# show vpc
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 10
Peer status : peer adjacency formed ok
vPC keep-alive status : peer is alive
Configuration consistency status: success
Per-vlan consistency status : success
Type-2 consistency status : success
vPC role : secondary
Number of vPCs configured : 9
Peer Gateway : Disabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Enabled
vPC Peer-link status
id Port Status Active vlans
1 Po1 up 10
vPC status
id Port Status Consistency Reason Active vlans
2 Po2 down* failed Consistency Check Not -
Performed
3 Po3 down* failed Consistency Check Not -
Performed
4 Po4 down* failed Consistency Check Not -
Performed
5 Po5 down* failed Consistency Check Not -
Performed
6 Po6 down* failed Consistency Check Not -
Performed
7 Po7 down* failed Consistency Check Not -
Performed
8 Po8 down* failed Consistency Check Not -
Performed
9 Po9 down* failed Consistency Check Not -
Performed
10 Po10 down* failed Consistency Check Not -
Performed
Thank you.
Sergiu.Daniluk
Hi @beta_admin66
Just to confirm, do you mean you tried to configure a Nexus 5010 and a Nexus 5020 in a vPC domain?
If yes, then the issue is, as you already guessed, hardware incompatibility. You can configure a vPC domain only with two identical switches.
I would recommend you read the following vPC design guide: https://www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/sw/design/vpc_design/vpc_best_practices_design_guide.pdf  It's the best vPC whitepaper out there.
Stay safe,
Sergiu
