Hello @Translator
The NXK-ACC-KIT-1RU is an accessory kit typically associated with Cisco networking equipment, specifically for rack-mounting purposes. It includes slider rails and other components for mounting 1RU (1 Rack Unit) devices in a standard 19-inch rack.
The slider rails specifications for the NXK-ACC-KIT-1RU are generally as follows:
- Compatibility: Designed for 1RU devices, such as Cisco Nexus switches or other compatible equipment.
- Rack Size: Fits standard 19-inch racks.
- Adjustable Depth: The rails are adjustable to accommodate racks of varying depths, typically ranging from approximately 24 inches to 36 inches.
- Material: Made of durable metal (usually steel) to support the weight of the equipment.
- Sliding Mechanism: Allows for easy access to the device for maintenance or replacement without fully removing it from the rack.
- Mounting Hardware: Includes screws, cage nuts, and other necessary hardware for installation.
For precise details, I suggest you to refer to the official Cisco documentation or the product datasheet for the NXK-ACC-KIT-1RU, as specifications may vary slightly depending on the specific model or version.
Hope This Helps!!!
AshSe
Forum Tips:
- Insert photos/images inline - don't attach.
- Always mark helpful and correct answers, it helps others find what they need.
- For a prompt reply, kindly tag @name. An email will be automatically sent to the member.
