Cisco nexus ERROR_VLANS_ERROR
hugo_fana
Hi you all,
I'm facing some issues and i'm not being capable of fix it.
So I'm working with a cisco nexus 5K and times to times I'm getting this log error:
2020 Feb 29 10:47:07.650 ca-str-dca %ETHPORT-3-IF_ERROR_VLANS_ERROR: VLANs 315,326,599,717-718,1308-1309,1316-1317,1320-1324,1326,1330,1344-1348,1351,1353-1354,1361,1376-1382,1392-1397 on Interface port-channel20 are in error state. (Reason: Vlan is not allowed on Peer-link)
This is just an example, cause I get this error in a bunch of port-channels.
I don't know why it says that the vlan is not allowed on Peer-Link, because all vlans are configured on port-channel peer-link.
The other issue is this constant message:
2020 Feb 29 10:40:27 ca-str-dca %USER-3-SYSTEM_MSG: parsing vsa:not a cisco vendor id:43 - radiusd
2020 Feb 29 10:40:37.439 ca-str-dca %ARP-3-DUP_VADDR_SRCIP: arp [3504] Source address of packet received from 0000.5e00.0164 on Vlan609 is duplicate of local virtual ip, 10.55.0.97
The virtual ip is the peer-link virtual ip.
Can you please help me out on this?
Thanks you all!!!
6 Replies 6
balaji.bandi
The error because the port-channel you building with end device is connected their uplink to 2 Parent Nexus switches, they are in VPC.
The VLAN should be allowed same also in vPC peer-link for active/active - that is the reason you getting that error.
Since your HSRP not formed correctly since there is no visibility between interface, you getting the duplicate IP. this will resolve once you fix the vPC peer link VLAN
you need further assitance please post the configuration of all device to confirm all configured as expected.
BB
Hi Balaji,
Sorry for the late answer, I was on vacation time and after that, all the concern about corona virus.
Well, I attached the configuration file to this answer.
By your answer, are you saying that both of Nexus should be active to get free of that error? Is it so?
Thanks so much for your help.
This is the configuration from the other Nexus.
Jason Leschnik
Does the issue resolve on it's own?
Could you share the output of
show spanning-tree internal info global | beg Total
Hi Jason,
Sorry, I was on vacation.
So, as you asked for:
Nexus A:
ca-str-dca# show spanning-tree internal info global | beg Total
Summary Totals: 1018 0 1018 0
------- STP Port Count Summary ---------------
Total stp_ports*instances: 1018
Total ports*vlans : 1018
Total phy_ports*vlans : 1300
------- SPS batch info -----------------------
sps_num_chunks : 1
sps_rr_token_list[ 0] : 0x0
sps_rr_token_list[ 1] : 0x0
sps_rr_token_list[ 2] : 0x0
sps_rr_token_list[ 3] : 0x0
sps_rr_token_list[ 4] : 0x0
sps_rr_token_list[ 5] : 0x0
sps_rr_token_list[ 6] : 0x0
sps_rr_token_list[ 7] : 0x0
sps_rr_token_list[ 8] : 0x0
sps_rr_token_list[ 9] : 0x0
sps_rr_token_list[10] : 0x0
sps_rr_token_list[11] : 0x0
sps_rr_token_list[12] : 0x0
sps_rr_token_list[13] : 0x0
sps_rr_token_list[14] : 0x0
sps_rr_token_list[15] : 0x0
sps_rr_token_list[16] : 0x0
sps_rr_token_list[17] : 0x0
sps_rr_token_list[18] : 0x0
sps_rr_token_list[19] : 0x0
sps_rr_token_list[20] : 0x0
sps_rr_token_list[21] : 0x0
sps_rr_token_list[22] : 0x0
sps_rr_token_list[23] : 0x0
sps_rr_token_list[24] : 0x0
sps_rr_token_list[25] : 0x0
sps_rr_token_list[26] : 0x0
sps_rr_token_list[27] : 0x0
sps_rr_token_list[28] : 0x0
sps_rr_token_list[29] : 0x0
sps_rr_token_list[30] : 0x0
sps_rr_token_list[31] : 0x0
sps_rr_token_list[32] : 0x0
sps_rr_token_list[33] : 0x0
sps_rr_token_list[34] : 0x0
sps_rr_token_list[35] : 0x0
sps_rr_token_list[36] : 0x0
sps_rr_token_list[37] : 0x0
sps_rr_token_list[38] : 0x0
sps_rr_token_list[39] : 0x0
sps_rr_token_list[40] : 0x0
sps_rr_token_list[41] : 0x0
sps_rr_token_list[42] : 0x0
sps_rr_token_list[43] : 0x0
sps_rr_token_list[44] : 0x0
sps_rr_token_list[45] : 0x0
sps_rr_token_list[46] : 0x0
sps_rr_token_list[47] : 0x0
sps_rr_token_list[48] : 0x0
sps_rr_token_list[49] : 0x0
sps_rr_token_list[50] : 0x0
sps_rr_token_list[51] : 0x0
sps_rr_token_list[52] : 0x0
sps_rr_token_list[53] : 0x0
sps_rr_token_list[54] : 0x0
sps_rr_token_list[55] : 0x0
sps_rr_token_list[56] : 0x0
sps_rr_token_list[57] : 0x0
sps_rr_token_list[58] : 0x0
sps_rr_token_list[59] : 0x0
sps_rr_token_list[60] : 0x0
sps_rr_token_list[61] : 0x0
sps_rr_token_list[62] : 0x0
sps_rr_token_list[63] : 0x0
sps_rr_token_list[64] : 0x0
sps_rr_token_list[65] : 0x0
sps_rr_token_list[66] : 0x0
sps_rr_token_list[67] : 0x0
sps_rr_token_list[68] : 0x0
sps_rr_token_list[69] : 0x0
sps_rr_token_list[70] : 0x0
sps_rr_token_list[71] : 0x0
sps_rr_token_list[72] : 0x0
sps_rr_token_list[73] : 0x0
sps_rr_token_list[74] : 0x0
sps_rr_token_list[75] : 0x0
sps_rr_token_list[76] : 0x0
sps_rr_token_list[77] : 0x0
sps_rr_token_list[78] : 0x0
sps_rr_token_list[79] : 0x0
sps_rr_token_list[80] : 0x0
sps_rr_token_list[81] : 0x0
sps_rr_token_list[82] : 0x0
sps_rr_token_list[83] : 0x0
sps_rr_token_list[84] : 0x0
sps_rr_token_list[85] : 0x0
sps_rr_token_list[86] : 0x0
sps_rr_token_list[87] : 0x0
sps_rr_token_list[88] : 0x0
sps_rr_token_list[89] : 0x0
sps_rr_token_list[90] : 0x0
sps_rr_token_list[91] : 0x0
sps_rr_token_list[92] : 0x0
sps_rr_token_list[93] : 0x0
sps_rr_token_list[94] : 0x0
sps_rr_token_list[95] : 0x0
sps_rr_token_list[96] : 0x0
sps_rr_token_list[97] : 0x0
sps_rr_token_list[98] : 0x0
sps_rr_token_list[99] : 0x0
sps_rr_token_list[100] : 0x0
sps_rr_token_list[101] : 0x0
sps_rr_token_list[102] : 0x0
sps_rr_token_list[103] : 0x0
sps_rr_token_list[104] : 0x0
sps_rr_token_list[105] : 0x0
sps_rr_token_list[106] : 0x0
sps_rr_token_list[107] : 0x0
sps_rr_token_list[108] : 0x0
sps_rr_token_list[109] : 0x0
sps_rr_token_list[110] : 0x0
sps_rr_token_list[111] : 0x0
sps_rr_token_list[112] : 0x0
sps_rr_token_list[113] : 0x0
sps_rr_token_list[114] : 0x0
sps_rr_token_list[115] : 0x0
sps_rr_token_list[116] : 0x0
sps_rr_token_list[117] : 0x0
sps_rr_token_list[118] : 0x0
sps_rr_token_list[119] : 0x0
sps_rr_token_list[120] : 0x0
sps_rr_token_list[121] : 0x0
sps_rr_token_list[122] : 0x0
sps_rr_token_list[123] : 0x0
sps_rr_token_list[124] : 0x0
sps_rr_token_list[125] : 0x0
sps_rr_token_list[126] : 0x0
sps_rr_token_list[127] : 0x0
sps_rr_token_list[128] : 0x0
sps_rr_token_list[129] : 0x0
sps_rr_token_list[130] : 0x0
sps_rr_token_list[131] : 0x0
sps_rr_token_list[132] : 0x0
sps_rr_token_list[133] : 0x0
sps_rr_token_list[134] : 0x0
sps_rr_token_list[135] : 0x0
sps_rr_token_list[136] : 0x0
sps_rr_token_list[137] : 0x0
sps_rr_token_list[138] : 0x0
sps_rr_token_list[139] : 0x0
sps_rr_token_list[140] : 0x0
sps_rr_token_list[141] : 0x0
sps_rr_token_list[142] : 0x0
sps_rr_token_list[143] : 0x0
sps_rr_token_list[144] : 0x0
sps_rr_token_list[145] : 0x0
sps_rr_token_list[146] : 0x0
sps_rr_token_list[147] : 0x0
sps_rr_token_list[148] : 0x0
sps_rr_token_list[149] : 0x0
sps_rr_token_list[150] : 0x0
sps_rr_token_list[151] : 0x0
sps_rr_token_list[152] : 0x0
sps_rr_token_list[153] : 0x0
sps_rr_token_list[154] : 0x0
sps_rr_token_list[155] : 0x0
sps_rr_token_list[156] : 0x0
sps_rr_token_list[157] : 0x0
sps_rr_token_list[158] : 0x0
sps_rr_token_list[159] : 0x0
sps_rr_token_list[160] : 0x0
sps_rr_token_list[161] : 0x0
sps_rr_token_list[162] : 0x0
sps_rr_token_list[163] : 0x0
sps_rr_token_list[164] : 0x0
sps_rr_token_list[165] : 0x0
sps_rr_token_list[166] : 0x0
sps_rr_token_list[167] : 0x0
sps_rr_token_list[168] : 0x0
sps_rr_token_list[169] : 0x0
sps_rr_token_list[170] : 0x0
sps_rr_token_list[171] : 0x0
sps_rr_token_list[172] : 0x0
sps_rr_token_list[173] : 0x0
sps_rr_token_list[174] : 0x0
sps_rr_token_list[175] : 0x0
sps_rr_token_list[176] : 0x0
sps_rr_token_list[177] : 0x0
sps_rr_token_list[178] : 0x0
sps_rr_token_list[179] : 0x0
sps_rr_token_list[180] : 0x0
sps_rr_token_list[181] : 0x0
sps_rr_token_list[182] : 0x0
sps_rr_token_list[183] : 0x0
sps_rr_token_list[184] : 0x0
sps_rr_token_list[185] : 0x0
sps_rr_token_list[186] : 0x0
sps_rr_token_list[187] : 0x0
sps_rr_token_list[188] : 0x0
sps_rr_token_list[189] : 0x0
sps_rr_token_list[190] : 0x0
sps_rr_token_list[191] : 0x0
sps_rr_token_list[192] : 0x0
sps_rr_token_list[193] : 0x0
sps_rr_token_list[194] : 0x0
sps_rr_token_list[195] : 0x0
sps_rr_token_list[196] : 0x0
sps_rr_token_list[197] : 0x0
sps_rr_token_list[198] : 0x0
sps_rr_token_list[199] : 0x0
sps_rr_token_list[200] : 0x0
sps_rr_token_list[201] : 0x0
sps_rr_token_list[202] : 0x0
sps_rr_token_list[203] : 0x0
sps_rr_token_list[204] : 0x0
sps_rr_token_list[205] : 0x0
sps_rr_token_list[206] : 0x0
sps_rr_token_list[207] : 0x0
sps_rr_token_list[208] : 0x0
sps_rr_token_list[209] : 0x0
sps_rr_token_list[210] : 0x0
sps_rr_token_list[211] : 0x0
sps_rr_token_list[212] : 0x0
sps_rr_token_list[213] : 0x0
sps_rr_token_list[214] : 0x0
sps_rr_token_list[215] : 0x0
sps_rr_token_list[216] : 0x0
sps_rr_token_list[217] : 0x0
sps_rr_token_list[218] : 0x0
sps_rr_token_list[219] : 0x0
sps_rr_token_list[220] : 0x0
sps_rr_token_list[221] : 0x0
sps_rr_token_list[222] : 0x0
sps_rr_token_list[223] : 0x0
sps_rr_token_list[224] : 0x0
sps_rr_token_list[225] : 0x0
sps_rr_token_list[226] : 0x0
sps_rr_token_list[227] : 0x0
sps_rr_token_list[228] : 0x0
sps_rr_token_list[229] : 0x0
sps_rr_token_list[230] : 0x0
sps_rr_token_list[231] : 0x0
sps_rr_token_list[232] : 0x0
sps_rr_token_list[233] : 0x0
sps_rr_token_list[234] : 0x0
sps_rr_token_list[235] : 0x0
sps_rr_token_list[236] : 0x0
sps_rr_token_list[237] : 0x0
sps_rr_token_list[238] : 0x0
sps_rr_token_list[239] : 0x0
sps_rr_token_list[240] : 0x0
sps_rr_token_list[241] : 0x0
sps_rr_token_list[242] : 0x0
sps_rr_token_list[243] : 0x0
sps_rr_token_list[244] : 0x0
sps_rr_token_list[245] : 0x0
sps_rr_token_list[246] : 0x0
sps_rr_token_list[247] : 0x0
sps_rr_token_list[248] : 0x0
sps_rr_token_list[249] : 0x0
sps_rr_token_list[250] : 0x0
sps_rr_token_list[251] : 0x0
sps_rr_token_list[252] : 0x0
sps_rr_token_list[253] : 0x0
sps_rr_token_list[254] : 0x0
sps_rr_token_list[255] : 0x0
sps_rr_token_list[256] : 0x0
sps_rr_token_list[257] : 0x0
sps_rr_token_list[258] : 0x0
sps_rr_token_list[259] : 0x0
sps_rr_token_list[260] : 0x0
sps_rr_token_list[261] : 0x0
sps_rr_token_list[262] : 0x0
sps_rr_token_list[263] : 0x0
sps_rr_token_list[264] : 0x0
sps_rr_token_list[265] : 0x0
sps_rr_token_list[266] : 0x0
sps_rr_token_list[267] : 0x0
sps_rr_token_list[268] : 0x0
sps_rr_token_list[269] : 0x0
sps_rr_token_list[270] : 0x0
sps_rr_token_list[271] : 0x0
sps_rr_token_list[272] : 0x0
sps_rr_token_list[273] : 0x0
sps_rr_token_list[274] : 0x0
sps_rr_token_list[275] : 0x0
sps_rr_token_list[276] : 0x0
sps_rr_token_list[277] : 0x0
sps_rr_token_list[278] : 0x0
sps_rr_token_list[279] : 0x0
sps_rr_token_list[280] : 0x0
sps_rr_token_list[281] : 0x0
sps_rr_token_list[282] : 0x0
sps_rr_token_list[283] : 0x0
sps_rr_token_list[284] : 0x0
sps_rr_token_list[285] : 0x0
sps_rr_token_list[286] : 0x0
sps_rr_token_list[287] : 0x0
sps_rr_token_list[288] : 0x0
sps_rr_token_list[289] : 0x0
sps_rr_token_list[290] : 0x0
sps_rr_token_list[291] : 0x0
sps_rr_token_list[292] : 0x0
sps_rr_token_list[293] : 0x0
sps_rr_token_list[294] : 0x0
sps_rr_token_list[295] : 0x0
sps_rr_token_list[296] : 0x0
sps_rr_token_list[297] : 0x0
sps_rr_token_list[298] : 0x0
sps_rr_token_list[299] : 0x0
sps_rr_token_list[300] : 0x0
sps_rr_token_list[301] : 0x0
sps_rr_token_list[302] : 0x0
sps_rr_token_list[303] : 0x0
sps_rr_token_list[304] : 0x0
sps_rr_token_list[305] : 0x0
sps_rr_token_list[306] : 0x0
sps_rr_token_list[307] : 0x0
sps_rr_token_list[308] : 0x0
sps_rr_token_list[309] : 0x0
sps_rr_token_list[310] : 0x0
sps_rr_token_list[311] : 0x0
sps_rr_token_list[312] : 0x0
sps_rr_token_list[313] : 0x0
sps_rr_token_list[314] : 0x0
sps_rr_token_list[315] : 0x0
sps_rr_token_list[316] : 0x0
sps_rr_token_list[317] : 0x0
sps_rr_token_list[318] : 0x0
sps_rr_token_list[319] : 0x0
sps_rr_token_list[320] : 0x0
sps_rr_token_list[321] : 0x0
sps_rr_token_list[322] : 0x0
sps_rr_token_list[323] : 0x0
sps_rr_token_list[324] : 0x0
sps_rr_token_list[325] : 0x0
sps_rr_token_list[326] : 0x0
sps_rr_token_list[327] : 0x0
sps_rr_token_list[328] : 0x0
sps_rr_token_list[329] : 0x0
sps_rr_token_list[330] : 0x0
sps_rr_token_list[331] : 0x0
sps_rr_token_list[332] : 0x0
sps_rr_token_list[333] : 0x0
sps_rr_token_list[334] : 0x0
sps_rr_token_list[335] : 0x0
sps_rr_token_list[336] : 0x0
sps_rr_token_list[337] : 0x0
sps_rr_token_list[338] : 0x0
sps_rr_token_list[339] : 0x0
sps_rr_token_list[340] : 0x0
sps_rr_token_list[341] : 0x0
sps_rr_token_list[342] : 0x0
sps_rr_token_list[343] : 0x0
sps_rr_token_list[344] : 0x0
sps_rr_token_list[345] : 0x0
sps_rr_token_list[346] : 0x0
sps_rr_token_list[347] : 0x0
sps_rr_token_list[348] : 0x0
sps_rr_token_list[349] : 0x0
sps_rr_token_list[350] : 0x0
sps_rr_token_list[351] : 0x0
sps_rr_token_list[352] : 0x0
sps_rr_token_list[353] : 0x0
sps_rr_token_list[354] : 0x0
sps_rr_token_list[355] : 0x0
sps_rr_token_list[356] : 0x0
sps_rr_token_list[357] : 0x0
sps_rr_token_list[358] : 0x0
sps_rr_token_list[359] : 0x0
sps_rr_token_list[360] : 0x0
sps_rr_token_list[361] : 0x0
sps_rr_token_list[362] : 0x0
sps_rr_token_list[363] : 0x0
sps_rr_token_list[364] : 0x0
sps_rr_token_list[365] : 0x0
sps_rr_token_list[366] : 0x0
sps_rr_token_list[367] : 0x0
sps_rr_token_list[368] : 0x0
sps_rr_token_list[369] : 0x0
sps_rr_token_list[370] : 0x0
sps_rr_token_list[371] : 0x0
sps_rr_token_list[372] : 0x0
sps_rr_token_list[373] : 0x0
sps_rr_token_list[374] : 0x0
sps_rr_token_list[375] : 0x0
sps_rr_token_list[376] : 0x0
sps_rr_token_list[377] : 0x0
sps_rr_token_list[378] : 0x0
sps_rr_token_list[379] : 0x0
sps_rr_token_list[380] : 0x0
sps_rr_token_list[381] : 0x0
sps_rr_token_list[382] : 0x0
sps_rr_token_list[383] : 0x0
sps_rr_token_list[384] : 0x0
sps_rr_token_list[385] : 0x0
sps_rr_token_list[386] : 0x0
sps_rr_token_list[387] : 0x0
sps_rr_token_list[388] : 0x0
sps_rr_token_list[389] : 0x0
sps_rr_token_list[390] : 0x0
sps_rr_token_list[391] : 0x0
sps_rr_token_list[392] : 0x0
sps_rr_token_list[393] : 0x0
sps_rr_token_list[394] : 0x0
sps_rr_token_list[395] : 0x0
sps_rr_token_list[396] : 0x0
sps_rr_token_list[397] : 0x0
sps_rr_token_list[398] : 0x0
sps_rr_token_list[399] : 0x0
sps_rr_token_list[400] : 0x0
sps_rr_token_list[401] : 0x0
sps_rr_token_list[402] : 0x0
sps_rr_token_list[403] : 0x0
sps_rr_token_list[404] : 0x0
sps_rr_token_list[405] : 0x0
sps_rr_token_list[406] : 0x0
sps_rr_token_list[407] : 0x0
sps_rr_token_list[408] : 0x0
sps_rr_token_list[409] : 0x0
sps_rr_token_list[410] : 0x0
sps_rr_token_list[411] : 0x0
sps_rr_token_list[412] : 0x0
sps_rr_token_list[413] : 0x0
sps_rr_token_list[414] : 0x0
sps_rr_token_list[415] : 0x0
sps_rr_token_list[416] : 0x0
sps_rr_token_list[417] : 0x0
sps_rr_token_list[418] : 0x0
sps_rr_token_list[419] : 0x0
sps_rr_token_list[420] : 0x0
sps_rr_token_list[421] : 0x0
sps_rr_token_list[422] : 0x0
sps_rr_token_list[423] : 0x0
sps_rr_token_list[424] : 0x0
sps_rr_token_list[425] : 0x0
sps_rr_token_list[426] : 0x0
sps_rr_token_list[427] : 0x0
sps_rr_token_list[428] : 0x0
sps_rr_token_list[429] : 0x0
sps_rr_token_list[430] : 0x0
sps_rr_token_list[431] : 0x0
sps_rr_token_list[432] : 0x0
sps_rr_token_list[433] : 0x0
sps_rr_token_list[434] : 0x0
sps_rr_token_list[435] : 0x0
sps_rr_token_list[436] : 0x0
sps_rr_token_list[437] : 0x0
sps_rr_token_list[438] : 0x0
sps_rr_token_list[439] : 0x0
sps_rr_token_list[440] : 0x0
sps_rr_token_list[441] : 0x0
sps_rr_token_list[442] : 0x0
sps_rr_token_list[443] : 0x0
sps_rr_token_list[444] : 0x0
sps_rr_token_list[445] : 0x0
sps_rr_token_list[446] : 0x0
sps_rr_token_list[447] : 0x0
sps_rr_token_list[448] : 0x0
sps_rr_token_list[449] : 0x0
sps_rr_token_list[450] : 0x0
sps_rr_token_list[451] : 0x0
sps_rr_token_list[452] : 0x0
sps_rr_token_list[453] : 0x0
sps_rr_token_list[454] : 0x0
sps_rr_token_list[455] : 0x0
sps_rr_token_list[456] : 0x0
sps_rr_token_list[457] : 0x0
sps_rr_token_list[458] : 0x0
sps_rr_token_list[459] : 0x0
sps_rr_token_list[460] : 0x0
sps_rr_token_list[461] : 0x0
sps_rr_token_list[462] : 0x0
sps_rr_token_list[463] : 0x0
sps_rr_token_list[464] : 0x0
sps_rr_token_list[465] : 0x0
sps_rr_token_list[466] : 0x0
sps_rr_token_list[467] : 0x0
sps_rr_token_list[468] : 0x0
sps_rr_token_list[469] : 0x0
sps_rr_token_list[470] : 0x0
sps_rr_token_list[471] : 0x0
sps_rr_token_list[472] : 0x0
sps_rr_token_list[473] : 0x0
sps_rr_token_list[474] : 0x0
sps_rr_token_list[475] : 0x0
sps_rr_token_list[476] : 0x0
sps_rr_token_list[477] : 0x0
sps_rr_token_list[478] : 0x0
sps_rr_token_list[479] : 0x0
sps_rr_token_list[480] : 0x0
sps_rr_token_list[481] : 0x0
sps_rr_token_list[482] : 0x0
sps_rr_token_list[483] : 0x0
sps_rr_token_list[484] : 0x0
sps_rr_token_list[485] : 0x0
sps_rr_token_list[486] : 0x0
sps_rr_token_list[487] : 0x0
sps_rr_token_list[488] : 0x0
sps_rr_token_list[489] : 0x0
sps_rr_token_list[490] : 0x0
sps_rr_token_list[491] : 0x0
sps_rr_token_list[492] : 0x0
sps_rr_token_list[493] : 0x0
sps_rr_token_list[494] : 0x0
sps_rr_token_list[495] : 0x0
sps_rr_token_list[496] : 0x0
sps_rr_token_list[497] : 0x0
sps_rr_token_list[498] : 0x0
sps_rr_token_list[499] : 0x0
------- STP Batched TCN Stats ---------------
Batched TCN (all-drop) pending: False
TCN Pending vlans:
Num Batched TCN sent: 2121
Nexus B:
ca-str-dcb# show spanning-tree internal info global | beg Total
Summary Totals: 1018 0 976 42
sps_num_chunks : 1
TCN Pending vlans:
Num Batched TCN sent: 3154
Thanks for those outputs.
The STP scale is well within the limits so that's fine. Need to make sure that the control-plane isn't seeing a large number of STP BPDU for some reason. If you run the following do you see any drops for the "bridging" or "stp" classes?
show policy-map interface control-plane     <<<<< It's called "bridging" here
show platform afm info copp-tbls            <<<<< "stp" here
Are you seeing anything else interesting in `show logging log`? Potentially anything regarding MAC Learning being disabled? Could you check for high CPU on either peer-switch:
show processes cpu history
Might also be worth looking to see if you're seeing a lot of MAC moves too. There is no impact running these command but it's also recommended to do so within a change window.
# First check what the current logging levels are
switch# show logging level | i i fwm|monitor|default Facility Default Severity Current Session Severity fwm 6 6 monitor 3 3 # Enable MAC move notifications
mac address table notification mac-move logging level fwm 6 logging monitor 6
# Monitor for MAC moves
show logging log | last 50
# Revert this with the following commands # Set the 'x' & 'y' values to the values you found from the first command under the column
#+ "Current Session Severity". For me that's fwm=6, monitor=3. These values might be different on
#+ your switch.
no mac address table notification mac-move logging level fwm x logging monitor y
Also
  • Which model of Nexus 5k?
  • What release of NX-OS?
  • What is the configuration of the peer-link?
    • How many links are in the peer-link?
  • For the peer-link port-channel please run `show run int poX members` where "X" is the peer-link port-channel number
    • Also check `show int poX counters errors`
Jason.
