Config BGP using VRRP/HSRP IP of Nexus cluster with a external device
nsmwella
Hi Experts,
Can config BGP peering with an external L3 device connected via VPC using the VRRP/HSRP IP of the Nexus cluster or can config BGP in Nexus cluster only configuring neighbor peerings with both the Nexus switches separately ?
Harold Ritter
Hi @nsmwella ,
It is preferable to configure two separate sessions, as described in the following document:
https://www.cisco.com/c/en/us/support/docs/ip/ip-routing/217099-ebgp-peering-over-vpc-on-nexus.html
