VXLAN EVPN Vlan 1
Soporteco
Does anyone know how can we configure Vlan 1 on VXLAN EVPN? We're using DCNM to deploy a fabric.
We can create any vlans ffrom 2-3967. We tried to configure manually:
leaf01-F(config)# vlan 1
leaf01-F(config-vlan)# vn-segment 30001
Message reported by command :: end
Can't configure vnsegment id for Native Vlan 1
Cannot run commands in the mode at this moment. Please try again.
ERROR: Failed to write VSH commands
It doesn't seem to allow it, but we need it!!
Appreciate any help.
perkin
I have the same problem too, will that able to fixed by native vlan setting?
any solution you found?
Hi Perkin.
The solution was to upgrade the code of the switches.
I guess our switches were Nexus 93108tc-ex and Nexus 93180yc-ex running version 9.2(2) and we upgraded to 9.2(3). After that, we could configure vlan 1 with its corresponding vnid, just as other vlans.
However DCNM doesn't allow to configure vlan 1 from "Networks" tab, so we had to configure Vlan 1 from the Leaf Freeform Config tab on Fabric Builder option.
configure profile vlan1
vlan 1
vn-segment 30001
interface Vlan1
vrf member VRF-name
no ip redirects
no ipv6 redirects
fabric forwarding mode anycast-gateway
no shutdown
Hello Soporteco, appreciated your response
and this is really good to hear that!
I am planning to move to VXLAN however I found this issue in DCNM lab test and googled a bit and only found this is the only one thread in the whole world...
thank for your help!
peterzhang
I am so grateful to find this post !!
but how did you apply this configuration profile thing ? after I configured profile, nothing happened. Meaning that when I do "show run int vlan1", I see blank configurations.
