04-10-2021 02:22 PM - edited 04-10-2021 06:56 PM
Can I connect the FEX(QSFP port) to NX-5600 with a breakout cable?
and if yes, does it matter what polarity(A, B or C) the cable is as long as I don't use patch panels in the middle?
I ordered Polarity B it hasn't arrived yet!
and the reason is because I have already used all my 5k qsfp ports!
Solved! Go to Solution.
04-13-2021 11:53 PM
Hi @Aaron_un
You have a list of supported QSFPs/Breakout cables for each model of N2K here:
Stay safe!
Sergiu
04-14-2021 11:27 AM
04-13-2021 11:53 PM
Hi @Aaron_un
Stay safe!
Sergiu
04-14-2021 11:27 AM
Cisco Live! BRKARC-3454
