971
Connection between Cisco Nexus 7K and Brocade VDX6740
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-19-2018 11:14 PM
I need to interconnect connect Cisco nexus 7k and Brocade VDX6740 switches and i have the following questions
1) Which is the easy way of connecting between these switches L2 or L3 connections?
2) If i use L3 connection between them, can i use static routes to point the routes in to that link with in the switch?
3)What are the best SFP+ 10G multi mode modules for cisco nexus 7k switch to support brocade switch?
Thanks for your help
Labels:
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-20-2018 09:03 AM
Please see mt responses inline :
Depends on your requirements, like if you are using the Brocade as access and Nexus 7K as core, I will do a L2 connection between them
Yes static route is one of the option
SFP-10G-SR
SFP-10G-SR
