Default route update on Nexus 7K
cheery Tomato
As per the attached picture.
I have 4 Nexus 7k which are connected via eBGP.
Nexus 3 & 4 advertise the default route to the Nexus 1 & 2
Nexus 1 & 2 are also connected to Router 1 & 2
Router 2 is advertising its default routes into EIGRP
Nexus 1 & 2 have a default route via eBGP to Nexus 3 & 4 in the routing table
and a default route in the EIGRP topology table to Router 2
eBGP default route with AD 20
EIGRP default route with AD 170
The connection to Nexus 3 & 4 is cut
Now the default is to Router 2 via EIGRP
The eBGP connection to Nexus 3 & 4 is restored
However the eBGP default does not take over from the EIGRP default route in the IP routing table.
I had to clear the ip routing tables default route to get the eBGP defalt route to take over.
Has anyone seen this behaviour, this seems to be a bug to me.
I would expect the IP routing table to update when the better route is avilable via eBGP when the connection is restored.
As always any help is greatly appreciated.
cheery Tomato
I added a local preference to route via the preffered path to fix the issue immediately.
Afterwards I found a BGP network 0.0.0.0 statement that then caused the default to originate on the offending router.
Removing this the issue was resolved for sure but have left the Local Preference in place anyway.
Cheers for the assistance.
Francesco Molino
Can you share the output of the following commands (in the scenario where default route is learned over eigrp and the ebgp isn't installed):
- sh ip bgp
- sh ip bgp 0.0.0.0
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
This is after the incident now but I am suseptable to it happening again.
So this is cut from my logs at the time when the incident occurred
Nexus3# sh ip bgp 0.0.0.0
BGP routing table information for VRF default, address family IPv4 Unicast
BGP routing table entry for 0.0.0.0/0, version 190443
Paths: (5 available, best #4)
Flags: (0x080012) on xmit-list, is in urib, is backup urib route
Path type: external, path is valid, not best reason: AS Path
AS-Path: 65530 64513 , path sourced external to AS
10.224.1.182 (metric 0) from 10.224.1.182 (10.224.1.182)
Origin IGP, MED not set, localpref 100, weight 0
Path type: internal, path is valid, not best reason: RR Cluster Length
AS-Path: NONE, path sourced internal to AS
10.8.255.35 (metric 130816) from 10.60.127.13 (10.60.127.13)
Origin IGP, MED 1707264, localpref 100, weight 0
Originator: 10.8.255.35 Cluster list: 10.60.127.13
Path type: internal, path is valid, not best reason: Neighbor Address
10.8.255.35 (metric 130816) from 10.224.16.2 (10.60.127.13)
Advertised path-id 1
Path type: internal, path is valid, is best path
10.8.255.35 (metric 130816) from 10.8.255.35 (10.8.255.35)
AS-Path: 64513 , path sourced external to AS
10.225.0.69 (metric 0) from 10.225.0.69 (10.8.255.6)
Path-id 1 advertised to peers:
10.60.127.13 10.60.127.16 10.224.1.182 10.224.16.2
10.225.0.69 10.231.1.13
Nexus3# sh ip route 0.0.0.0
IP Route Table for VRF "default"
'*' denotes best ucast next-hop
'**' denotes best mcast next-hop
'[x/y]' denotes [preference/metric]
'%<string>' in via output denotes VRF <string>
0.0.0.0/0, ubest/mbest: 1/0
*via 10.50.244.10, Eth3/18, [170/1707008], 2d03h, eigrp-1, external
via 10.8.255.35, [200/1707264], 01:24:39, bgp-64551, internal, tag 64551
Nexus3# clear ip route 0.0.0.0
Clearing 0.0.0.0/32
*via 10.225.0.69, [20/0], 00:04:32, bgp-64551, external, tag 64513
via 10.50.244.10, Eth3/18, [170/1707008], 00:01:29, eigrp-1, external
Can you run the sh ip bgp 0.0.0.0 when the ebgp route is installed. There's something that doesn't match your design and just want to validate please.
Also can you share the config of your bgp and eigrp config just in case.
Francesco
cheery Tomato
