Deploying F5 Loadbalancer within Nexus VxLAN 9000 deployment None-ACI
V120311
    I am looking to see if it's possible to deploy an F5 Loadbalancer within a VxLAN 9000 deployment which is not running ACI? Is there so Cisco deployment guide or any other guide which someone can recommend. I was planning on using a border leaf to connect the F5 Loadbalancer if that's what's recommended in such a design.
Thank you,
Victor
balaji.bandi
If there is no ACI, you need to Treak Nexus Switch as Switch in DC Evnronment and connect as usual with network requirement, i do not see any special requirement you need to deploy F5 here.
do you have any special requirement please explain.
like any SGT / ISE kind of  then follow below link for more information :
https://community.cisco.com/t5/security-documents/how-to-cisco-amp-f5-deployment-guide-ise-load-balancing-using/ta-p/3631159
BB
