Disable weak ciphers on Nexus 5548
nurairtt
Is there a way we can disable weak ciphers, hmac and key exchange algorithm on Nexus 5548 running 7.3(13). I do not find any option to disable or view the current settings.
Please help.
2 Accepted Solutions
anpetit
Hello @nurairtt ,
Hope you are doing well.
Yes you can do it since 7.3.1 on Nexus 5548, nevertheless you will need a specific debug plugin to be able to achieve your goal.
This can be provided by TAC if you are opening a TAC Case. This is the only way.
Hope it helps and have a nice day.
Kind Regards,
Antoine
Hello @nurairtt ,
Thank you for the helpful vote on my reply.
Is it possible to accept this reply as a solution to close this thread ?
Thanks for your cooperation and have a wonderful day.
Kind Regards,
Antoine
anpetit
Hello @nurairtt ,
Kind Regards,
Antoine
Hello @nurairtt ,
Kind Regards,
Antoine
