EVPN + VXLAN Multi-AS eBGP design issue
satish.txt1
I am labbing to learn eBGP underlay for EVPN so i did create following lab
Spine: 65000
Leaf-1:65001
Leaf-2:65002
## spine
router bgp 65000
  log-neighbor-changes
  address-family ipv4 unicast
    redistribute direct route-map TAG-UL
  address-family l2vpn evpn
    nexthop route-map NH-UNCH
    retain route-target all
  neighbor 10.1.1.1
    remote-as 65001
  neighbor 10.1.2.1
    remote-as 65002
  neighbor 10.255.1.1
    remote-as 65001
    update-source loopback0
    ebgp-multihop 3
      disable-peer-as-check
      send-community
      route-map NH-UNCH out
      rewrite-evpn-rt-asn
  neighbor 10.255.2.1
    remote-as 65002
    ebgp-multihop 3
      send-community
      rewrite-evpn-rt-asn
## leaf-1 and leaf-2 pretty similar except router-ID and peer IP
router bgp 65001
  neighbor 10.1.1.0
    remote-as 65000
  neighbor 10.255.255.1
    remote-as 65000
    disable-connected-check
    ebgp-multihop 3
      send-community
      send-community extended
      rewrite-evpn-rt-asn
evpn
  vni 10010 l2
    rd auto
    route-target import auto
    route-target export auto
## I have two server connected to leaf in 10010 VNI and spine BGP can see them in routing table
spine-1# show bgp l2vpn evpn
BGP routing table information for VRF default, address family L2VPN EVPN
BGP table version is 475, Local Router ID is 10.255.255.1
Status: s-suppressed, x-deleted, S-stale, d-dampened, h-history, *-valid, >-best
Path type: i-internal, e-external, c-confed, l-local, a-aggregate, r-redist, I-i
njected
Origin codes: i - IGP, e - EGP, ? - incomplete, | - multipath, & - backup, 2 - b
est2
   Network            Next Hop            Metric     LocPrf     Weight Path
Route Distinguisher: 10.255.1.1:32777
*>e[2]:[0]:[0]:[48]:[5254.0014.e6b8]:[0]:[0.0.0.0]/216
                      10.254.1.1                                     0 65001 i
*>e[3]:[0]:[32]:[10.254.1.1]/88
Route Distinguisher: 10.255.2.1:32777
*>e[2]:[0]:[0]:[48]:[5254.0019.9dcb]:[0]:[0.0.0.0]/216
                      10.254.2.1                                     0 65002 i
*>e[3]:[0]:[32]:[10.254.2.1]/88
## i am getting BGP update error on leaf saying RT policy reject and its not installing routers in FIB
leaf-1# show bgp l2vpn evpn
BGP table version is 175, Local Router ID is 10.255.1.1
njected
est2
Route Distinguisher: 10.255.1.1:32777    (L2VNI 10010)
*>l[2]:[0]:[0]:[48]:[5254.0014.e6b8]:[0]:[0.0.0.0]/216
                      10.254.1.1                        100      32768 i
*>l[3]:[0]:[32]:[10.254.1.1]/88
## BGP error on leaf-1 (10.255.255.1 is spine Loopback)
2020 Aug 7 13:52:29.759596 bgp: [14564] (default) UPD: [L2VPN EVPN] 10.255.255.1 Inbound import RT check action deny 2020 Aug 7 13:52:29.759906 bgp: [14564] (default) UPD: Received ESI 0000.0000.0000.0000.0000 for route type 2 from peer 10.255.255.1
2020 Aug 7 13:52:29.759957 bgp: [14564] (default) UPD: [L2VPN EVPN] Received rd 10.255.2.1:32777 prefix [2]:[0]:[0]:[48]:[5254.0019.9dcb]:[0]:[0.0.0.0]/112 from peer 10.255.255.1, origin 0, next hop 10.254.2.1, localpref 0, med 0 2020 Aug 7 13:52:29.759987 bgp: [14564] (default) UPD: [L2VPN EVPN] Dropping prefix [2]:[0]:[0]:[48]:[5254.0019.9dcb]:[0]:[0.0.0.0]/112 from peer 10.255.255.1, due to attribute policy rejected
@Sergiu.Daniluk  I found my problem, if you look at Spine configuration which i posted had only standard community instead of extended
send-community
 After change to send-community both it works (sorry it was my typo)
Following will required to make route-target both auto, it will overwrite RT with local ASN before inserting to FIB
rewrite-evpn-rt-asn
Sergiu.Daniluk
Hi @satish.txt1
What are the results if you statically define the route-targets?
Also, just to confirm, do you have 10.254.2.1 in the routing table of Leaf1?
Stay safe,
Sergiu
send-community
rewrite-evpn-rt-asn
