Facing issue while configuring SSH key in Nexus 7k
rakesh nair
Hi Team,
I need help in configuring ssh rsa key in nexus switch which is of model C7710
PPC-R3-1-NXMGT-15-21(config)# ssh key rsa 2048 force
deleting old rsa key.....
ssh server is enabled, cannot delete/generate the keys
This is the error i am getting.
rakesh nair
Thanks Nawir, I got the solution from Cisco TAC.
Below are the detailed steps
Login to admin VDC and enable telnet feature
Switch(config)# feature telnet
The login via telnet to admin vdc and perform below steps
Switch(config)# no feature ssh
XML interface to system may become unavailable since ssh is disabled
Switch(config)# no ssh key
Switch(config)# ssh key rsa 2048 force
generating rsa key(2048 bits).....
generated rsa key
Switch(config)# feature ssh
Switch(config)#
Login via SSH again and disable telnet feature if not required
Switch(config)# no feature telnet
rakesh nair
Can anyone please help
nawir
-recreate ssh key
#no feature ssh
# feature ssh
rakesh nair
generated rsa key
Switch(config)#
