Guest port is up but blocked
cajalat
I'm running into a problem with Guests's ports in a blocked state.  From the vSphere interface the ports are in a blocked state (see attachment).  From the Nexus CLI I get this:
nexus-1# sh interface status
Port           Name               Status   Vlan      Duplex  Speed   Type
mgmt0          --                 up       routed    full    1000    --
Eth3/6         --                 up       trunk     full    1000    --
Eth3/8         --                 up       trunk     full    1000    --
Eth4/6         --                 up       trunk     full    1000    --
Eth4/8         --                 up       trunk     full    1000    --
Po1            --                 up       trunk     full    1000    --
Po2            --                 up       trunk     full    1000    --
Veth1          TESTMACHINE-Casey, down     1141      auto    auto    --
Veth2          TESTMACHINE2-Casey down     1141      auto    auto    --
ctrl0          --                 up       routed    full    1000    --
I can't figure out why that's the case.  I made sure that vlan 1141 is trunked all the way up to the VEM and is visible on the network and both the control/packet vlans are visible to the VEM/VSM.
Any guidance is much appreciated.
Casey
6 Replies 6
srsardar
Can you post the running configuration. There are multiple reasons why the port could be down. Policies applied on the port might be getting rejected during the port bring up , Vlan not being active internally.
I meant to include the config...:)  Here it is:
nexus-1# sh run
version 4.0(4)SV1(2)
username admin password 5 *******************  role network-admin
telnet server enable
ssh key rsa 2048
ip domain-lookup
ip host nexus-1 10.36.100.14
kernel core target 0.0.0.0
kernel core limit 1
system default switchport
vem 3
  host vmware id 34343335-3237-5553-4539-343956574e46
vem 4
  host vmware id 34343335-3232-5553-4539-343956574e48
snmp-server user admin network-admin auth md5 0x******************priv 0x***********************localizedkey
snmp-server enable traps license
vrf context management
  ip route 0.0.0.0/0 10.36.100.1
hostname nexus-1
vlan 1
vlan 1100
  name Management
vlan 1108
  name TESTVLAN1
vlan 1109
  name TESTVLAN2
vdc nexus-1 id 1
  limit-resource vlan minimum 16 maximum 513
  limit-resource monitor-session minimum 0 maximum 64
  limit-resource vrf minimum 16 maximum 8192
  limit-resource port-channel minimum 0 maximum 256
  limit-resource u4route-mem minimum 32 maximum 80
  limit-resource u6route-mem minimum 16 maximum 48
port-profile type vethernet GUEST-DATA
  vmware port-group
  switchport mode access
  switchport access vlan 1141
  no shutdown
  state enabled
port-profile type ethernet SYSTEM-UPLINK
  vmware port-group
  switchport mode trunk
  switchport trunk allowed vlan 1100,1108-1109,1141
  channel-group auto mode on sub-group cdp
  no shutdown
  system vlan 1108-1109
  state enabled
port-profile type ethernet Unused_Or_Quarantine_Uplink
  description Port-group created for Nexus1000V internal usage. Do not use.
  vmware port-group
  shutdown
  state enabled
port-profile type vethernet Unused_Or_Quarantine_Veth
  vmware port-group
  shutdown
  state enabled
interface port-channel1
  inherit port-profile SYSTEM-UPLINK
interface port-channel2
interface Ethernet3/6
interface Ethernet3/8
interface Ethernet4/6
interface Ethernet4/8
interface mgmt0
  ip address 10.36.100.14/24
interface Vethernet1
  inherit port-profile GUEST-DATA
  description TESTMACHINE-Casey, Network Adapter 1
  vmware dvport 272
  no shutdown
interface Vethernet2
  description TESTMACHINE2-Casey, Network Adapter 1
  vmware dvport 264
interface control0
boot kickstart bootflash:/nexus-1000v-kickstart-mz.4.0.4.SV1.2.bin sup-1
boot system bootflash:/nexus-1000v-mz.4.0.4.SV1.2.bin sup-1
boot kickstart bootflash:/nexus-1000v-kickstart-mz.4.0.4.SV1.2.bin sup-2
boot system bootflash:/nexus-1000v-mz.4.0.4.SV1.2.bin sup-2
svs-domain
  domain id 100
  control vlan 1108
  packet vlan 1109
  svs mode L2
svs connection vcenter
  protocol vmware-vim
  remote ip address 10.36.131.148 port 81
  vmware dvs uuid "df 36 2e 50 ee 2f a4 a8-d8 f2 c8 28 5e 32 1f 27" datacenter-name Informatics
  connect
nexus-1#
Casey,
This type of error is usually a result of the uplink configuration.
- From vCenter can you display and capture the CDP information of the VEM interfaces connecting to the DVS
- Can you give a brief description of the topology used here.  (Upstream Switch types/models etc).
- Paste the switchport configuration of the ports to which the VEM's are connected to.
- If your VEM modules show on the VSM (show mod) provide the output of:
module vem 3 execute vemcmd show port
module vem 3 execute vemcmd show trunk
module vem 3 execute vemcmd show pc
- If your VEM modules are not showing up on the VSM, from your VEM CLI can you provide the following outputs:
vemcmd show port
vemcmd show trunk
vemcmd show pc
I see you're using sub-group CDP which is fine as long as you're CDP is functioning correctly.  Personally I prefer using mac-pinning as it doesn't require any upstream switchport configuration (other than setting the ports as trunks).
Provide the answers/info requested and we'll sort out whichever method you wish to use.
Robert
Robert,
Thank you for the troubleshooting tips.  I'm sure I'll use those at some point.  I didn't have access to the ESX host over the weekend to execute these commands.  The problem was a simple lack of VLAN definition on the VSM (see above).
Casey
Hi Casey,
the guest-vlan 1141 is missing in your configuration. Just add it, this should resolve the problem. Maybe a shut/noshut on the veth is necessary. Ports that are assigned to a not existing vlan, will show up as blocked in vCenter.
Cheers,
Jens
Thank you.  That was the problem.  The fact that this switch is virtual is getting in the way of my thinking.  I had assumed that only the mgmt/control/data vlans needed to be defined but it makes sense that I need to define all vlans to be used here.  Thanks again.
