01-23-2014 02:04 AM
Hi all,
i'm implementig vxlan on the new version of 1000v (4.2.1.SV2.2.1a) on esxi5.5 and Vsphere 5.5. I try this in my lab.
I'm encountering some problems with the multicast implentation of vxlan, on a l2 mode between vsm and vem, and on a l2 domain.
I see the multicast correctly encapsulated by vtep vem, The bridge groups are ok , with the right Veths. But i 've some problems with the igmp ( no reports are receveid from esxi hosts)
The vtep interfaces receives the queries from the uplink switch :
cisco1000v_lab_l2(vem-attach)# vemcmd show vxlan interfaces
LTL VSM Port IP Seconds since Last Vem Port
IGMP Query Received
(* = IGMP Join Interface/Designated VTEP)
49 Veth1 172.28.19.98 27 vmk1 *
vem 4
IGMP Query Received
49 Veth2 172.28.19.99 10 vmk1
ONLY multicast is encapsulated, and no unicast and arp from the remote ip
cisco1000v_lab_l2(vem-attach)# vemcmd show l2 bd-name vxw-dvs-217-virtualwire-6-sid-5003-dvs.VCDVSDataCenter-dmz-01-d53ae0b8-7d68-4b24
Bridge domain 12 brtmax 4096, brtcnt 1, timeout 300
Segment ID 5003, swbd 4096, "vxw-dvs-217-virtualwire-6-sid-5003-dvs.VCDVSDataCenter-dmz-01-d53ae0b8-7d68-4b24"
Flags: P - PVLAN S - Secure D - Drop
Type MAC Address LTL timeout Flags PVLAN Remote IP DSN
Static 00:50:56:a0:3d:d9 54 0 0.0.0.0 0
cisco1000v_lab_l2(vem-attach)# exit
cisco1000v_lab_l2# attach vem 4
Static 00:50:56:01:00:0e 51 0 0.0.0.0 0
cisco1000v_lab_l2(vem-attach)# vemcmd show vxlan-stats
LTL Ucast Mcast/Repl Ucast Mcast Total
Encaps Encaps Decaps Decaps Drops
49 0 707 0 0 0
52 0 91 0 0 0
54 0 19 0 0 0
49 0 640 0 0 0
51 0 566 0 0 0
I try to sniff the Multicast leaving/entering the VEM, and i see only the queries from my upstream switch to the 224.0.0.1 all host group.
But no one answer to the queries with a report message ...
With the vempkt command i capture in ingress only the query message entering the ltl 561 ( portchannel uplink for the vxlan in vlan 400)
------SF Packet Information------
Capture Stage : Ingress
Source LTL : 20 (561)
Destination LTL : 0
HWBD : 10
Vlan/SegID : 400
------Packet L3 Header Information------
Source IP Address : 172.28.19.97
Destination IP Address : 224.0.0.1
IP Protocol Type: 2
------Packet L2 Header Information------
Source MAC Address : 00:26:51:0f:1c:00
Destination MAC Address : 01:00:5e:00:00:01
Type : 2048
Payload :
00000: 01 00 5e 00 00 01 00 26 51 0f 1c 00 08 00 46 c0
00016: 00 20 c4 e6 00 00 01 02 bf b2 ac 1c 13 61 e0 00
00032: 00 01 94 04 00 00 11 64 ee 9b 00 00 00 00 00 00
00048: 00 00 00 00 00 00 00 00 00 00 00 00
NO report received from the veth1, corresponding to the vmk1 with vxlan capability...
Even with the capture egress, i see only the query from the upstream switch towards the veth1, vmk1, but not answer from the vmk1...
Can someone help me? Is there some incompatibility with the queries igmp send from the uplink switch 2960 c2960-lanlitek9-mz.122-58.SE2 and the esxi version 5.5 ? The configuration of 2960 is :
ip igmp snooping querier address 172.28.19.97
I need to upgrade to new version of 1000v , but i must solve this problem first....
Thank in advance
Federica
Solved! Go to Solution.
01-30-2014 11:12 AM
Hello federica,
Could you please check the firewall option if IGMP traffic is allowed? This could be verified using the command.
localcli --plugin-dir /usr/lib/vmware/esxcli/int networkinternal firewall get
If is disabled, could you please set the firewall option to allow igmp, using the below command:
localcli --plugin-dir /usr/lib/vmware/esxcli/int networkinternal firewall set --pass-igmp true
Please let me know if is fixing the issue.
Srikanth
01-30-2014 11:12 AM
Hello federica,
Srikanth
