11-20-2022 10:03 PM
Hi everyone,
In Our ACI fabric We have 6 leaves and 2 spines.
the user cpu and memory are normal.
But the kernel CPU and memory are always between 80% and 100%.
our APIC and switches version are 5.2(3e) and 15.2(3e) in order
Any ideas might help
Tnx in advane.
Solved! Go to Solution.
11-25-2022 09:29 PM
Hello Sinaa
Sounds like a bug
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwb48207
I think you need upgrade your ACI devices ,the fixed version is 15.2(6e), I think this issue (kernel CPU is a cosmetic bug)
regards
11-24-2022 01:39 PM
Hello Sinaa
did you check your current ACI Leaves and Spines Capacity?
regards
11-25-2022 09:09 PM
Yes, all parameters are less than 10 percent
11-25-2022 09:16 PM
are you experimented some connectivity issues?
regards
11-25-2022 09:29 PM
Hello Sinaa
Sounds like a bug
regards
