Bookmark
Subscribe
3103
High kernel CPU and memory utilization on ACI leaf switches
sina.naser
Hi everyone,
In Our ACI fabric We have 6 leaves and 2 spines.
the user cpu and memory are normal.
But the kernel CPU and memory are always between 80% and 100%.
our APIC and switches version are 5.2(3e) and 15.2(3e) in order
Any ideas might help
Tnx in advane.
Hello Sinaa
Sounds like a bug
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwb48207
I think you need upgrade your ACI devices ,the fixed version is 15.2(6e), I think this issue (kernel CPU is a cosmetic bug)
regards
jairhern
Hello Sinaa
did you check your current ACI Leaves and Spines Capacity?
regards
Yes, all parameters are less than 10 percent
are you experimented some connectivity issues?
regards
Hello Sinaa
Sounds like a bug
regards
