How to configure Multicast Layer 2 on Nexus 7000
williammanurung
Hi All,
 I have problem with my multicast traffic, the topology like this:
Configuration on nexus 7000 Box 1:
interface Vlan951
  ip address 10.204.137.66/27
  ip ospf passive-interface
  ip router ospf 1 area 0.0.0.207
  hsrp 951
       ip 10.204.137.65
Configuration on nexus 7000 Box 2:
interface Vlan951
  ip address 10.204.137.67/27
  hsrp 951
       ip 10.204.137.65
Verification on Box 1 and Box 2:
show ip igmp snooping vlan 951
#IGMP Snooping information for vlan 951
  IGMP snooping enabled
  Lookup mode: IP
  Optimised Multicast Flood (OMF) enabled
  IGMP querier none
  Switch-querier disabled
  IGMPv3 Explicit tracking enabled
  IGMPv2 Fast leave disabled
  IGMPv1/v2 Report suppression enabled
  IGMPv3 Report suppression disabled
  Link Local Groups suppression enabled
  Router port detection using PIM Hellos, IGMP Queries
  Number of router-ports: 1
  Number of groups: 27
  VLAN vPC function enabled
  Active ports:
    Po24
the problem is, packet multicast cannot forward and receive on server vlan 951.
My question:
1. By default, igmp snooping layer 2 enable. Will I configuring another command to enable multicast layer 2?
2. can you give me how to configure multicast layer 2 on nexus 7000? and how to verify it?
3. can you give me how to configure multicast layer 2 onFabric interconnect? and how to verify it?
mojafri
Hi William,
Please follow the below example:
https://www.cisco.com/c/en/us/support/docs/servers-unified-computing/unified-computing-system/117360-configure-product-00.html#anc6
Please rate if you find it helpful.
MJ
