10-29-2018 04:04 PM
I have a pair of Nexus 5500 switches that were previously used with layer 3 daughter cards. I would like to perform an ISSU on them, but am prevented by the presence of the LAN Base license. I can't seem to find any documentation on how to remove this old layer 3 license from the switch. Can anyone help?
Thanks in advance,
Solved! Go to Solution.
10-29-2018 04:27 PM
Hello Mike,
You can find the details below:
Please refer to the section "unistalling licenses"
The syntax as it states is "clear license <license name>
"You can only uninstall a permanent license that is not in use. If you try to delete a permanent license that is currently being used, the software rejects the request and issues an error message. "
HTH,
Orlando
10-29-2018 04:27 PM
Hello Mike,
HTH,
Orlando
