Installing and configuring 1000v
vaishali_palkar
Hi ,
I have downloaded Nexus1000v.4.0.4.SV1.3 and trying to install it.
Installation works fine till I reach the step to register 1000v plug-in on vcenter server.
"new plugin" is always disabled.
I tried command : show vmware vc extension-key on switch console.
It show extension-id :Cisco_Nexsus_1000v_1203930214
What may be the reason , I am not able to register the plugin ?
I cannot proceed futher.
I hope somebody will help me solving this issue.
Vaishali
32 Replies 32
Please let me know whether this port profile will work or not
1. 3 pnics on host
   1 nic - eth3/1 - ip addrees 10.192.10.175
   It is used for management port.
   It is on 1 gb switch.
   I do not want to configure port channel on this switch.
   2 nics - eth3/2 - These 2 are portchannel using LACP.
            eth3/3
   These 2 are on n5k switch.
   The corrosponding ports on n5k switch are port channeled using LACP.
So , is this port-channel information ok:
1. port-profile ethernet uplinkprof
2. capability uplink
3. vmware port-group
4. switch mode port trunk
5. switchport trunk allowed vlan 5 , 10
6. channel-group auto mode active subgroup cdp
7. no shutdown
8. system vlan 1
9. state enabled
int ethernet 3/2
inherit port-profileuplinkProf
int ethernet 3/3
So , for pnic eth3/1 , I am not using port profile because I do not want it to be part of uplink but I need that interface for management purpose.
Is this the correct configutaion or i have to do something else?
Can you please help to figure out the best configutaion for ports I mentioned earlier ?
Vaishali,
Couple of comments:
In your sample config, you define "system vlan 1" however you're  not allowing this over the trunk.  Any systems VLANs defined still need  to be allowed over the trunk interfaces.
7. no  shutdown
8. system vlan 1
9. state enabled
If you are separating your Management and  VM uplink traffic you need a separate Uplink Port Profile for each.  LACP will not bring up a Port Channel with a single interface.  Since you want your VM uplink using 2 x 10G nics channeled with LACP and your single 1G Management NIC alone, you would need two ethernet profiles like:
port-profile type ethernet Management-Uplink
capability uplink
vmware  port-group
switchport mode access
switchport access vlan <Mgmt VLAN>
no  shutdown
system vlan <Mgmt VLAN>
state enabled
port-profile type ethernet VM-Uplink
capability uplink
vmware  port-group
switchport mode trunk
switchport trunk allowed vlan x,y,z     <===[EXCLUDING YOUR MGMT VLAN!!]
no  shutdown
system vlan <Control, Packet, IP Storage VLANs>
state enabled
You would then assign your single GB nic to the first Uplink Port Profile in vCenter, and your 2 x 10G nics to the second.
Robert
