09-29-2020 07:28 AM - edited 09-29-2020 07:49 AM
I'm trying to setup EVPN with Anycast Gateway in my lab and having some issues routing between the L3 networks. I have attached a diagram, some configs and some outputs from each switch. My issue is I can't communicate between devices on different VLANs on different switches.
Initially I was trying to get a device on one switch to ping a device on another switch in a different VLAN:
PC6 on switch1 (VLAN 301 172.16.100.100) to ping PC7 on switch 2 (VLAN 302 172.16.200.100)
Switch1 does have a route for it:
nexus-sw1# show ip route 172.16.200.100 vrf Tenant-1 IP Route Table for VRF "Tenant-1" '*' denotes best ucast next-hop '**' denotes best mcast next-hop '[x/y]' denotes [preference/metric] '%<string>' in via output denotes VRF <string> 172.16.200.100/32, ubest/mbest: 1/0 *via 2.2.2.2%default, [200/0], 02:10:10, bgp-65535, internal, tag 65535 (evp n) segid: 900001 tunnelid: 0x2020202 encap: VXLAN
The opposing switch1 has a route back as well:
nexus-sw2# show ip route 172.16.100.100 vrf Tenant-1 IP Route Table for VRF "Tenant-1" '*' denotes best ucast next-hop '**' denotes best mcast next-hop '[x/y]' denotes [preference/metric] '%<string>' in via output denotes VRF <string> 172.16.100.100/32, ubest/mbest: 1/0 *via 1.1.1.1%default, [200/0], 01:50:24, bgp-65535, internal, tag 65535 (evp n) segid: 900001 tunnelid: 0x1010101 encap: VXLAN
If I create the Layer2 VNI and Anycast gateway for VLAN vlan 302 on Switch1 I am able to ping between the VLANs. (So: PC6 on switch1 (VLAN 301 172.16.100.100) to ping PC8 on switch1 (VLAN 302 172.16.200.250))
Diagram:
Configuration for Switch1:
nexus-sw1# sh run nv overlay evpn feature ospf feature bgp feature interface-vlan feature vn-segment-vlan-based feature nv overlay fabric forwarding anycast-gateway-mac 0000.2222.3333 vlan 1,101-102,301-302,900,1000-1001 vlan 101 vn-segment 900001 vlan 301 vn-segment 5501 vlan 302 vn-segment 5502 vrf context Tenant-1 vni 900001 rd auto address-family ipv4 unicast route-target both auto route-target both auto evpn hardware access-list tcam region vpc-convergence 0 hardware access-list tcam region arp-ether 256 interface Vlan101 desc L3-VNI no shutdown vrf member Tenant-1 ip forward interface Vlan301 description app no shutdown vrf member Tenant-1 ip address 172.16.100.1/24 fabric forwarding mode anycast-gateway interface Vlan302 description db no shutdown vrf member Tenant-1 ip address 172.16.200.1/24 fabric forwarding mode anycast-gateway interface nve1 no shutdown host-reachability protocol bgp source-interface loopback0 member vni 5501 suppress-arp ingress-replication protocol bgp member vni 5502 suppress-arp ingress-replication protocol bgp member vni 900001 associate-vrf interface Ethernet1/1 no switchport ip address 10.10.10.1/30 ip router ospf 10 area 0.0.0.0 no shutdown interface Ethernet1/6 switchport access vlan 302 interface Ethernet1/7 switchport access vlan 301 interface loopback0 ip address 1.1.1.1/32 ip router ospf 10 area 0.0.0.0 router ospf 10 router bgp 65535 router-id 1.1.1.1 neighbor 2.2.2.2 remote-as 65535 update-source loopback0 address-family l2vpn evpn send-community send-community extended evpn vni 5501 l2 rd auto route-target import auto route-target export auto vni 5502 l2 rd auto route-target import auto route-target export auto Troubleshooting Commands: ------------------------- nexus-sw2# show ip route 172.16.100.100 vrf Tenant-1 IP Route Table for VRF "Tenant-1" '*' denotes best ucast next-hop '**' denotes best mcast next-hop '[x/y]' denotes [preference/metric] '%<string>' in via output denotes VRF <string> 172.16.100.100/32, ubest/mbest: 1/0 *via 1.1.1.1%default, [200/0], 01:50:24, bgp-65535, internal, tag 65535 (evp n) segid: 900001 tunnelid: 0x1010101 encap: VXLAN nexus-sw1# show nve vni Codes: CP - Control Plane DP - Data Plane UC - Unconfigured SA - Suppress ARP SU - Suppress Unknown Unicast Interface VNI Multicast-group State Mode Type [BD/VRF] Flags --------- -------- ----------------- ----- ---- ------------------ ----- nve1 5501 UnicastBGP Up CP L2 [301] SA nve1 5502 UnicastBGP Up CP L2 [302] SA nve1 900001 n/a Up CP L3 [Tenant-1]
Configuration for Switch2:
nexus-sw2# shrun nv overlay evpn feature ospf feature bgp feature interface-vlan feature vn-segment-vlan-based feature nv overlay fabric forwarding anycast-gateway-mac 0000.2222.3333 vlan 1,101-102,302,900,1000-1001 vlan 101 vn-segment 900001 vlan 302 vn-segment 5502 vrf context Tenant-1 vni 900001 rd auto address-family ipv4 unicast route-target both auto route-target both auto evpn hardware access-list tcam region vpc-convergence 0 hardware access-list tcam region arp-ether 256 interface Vlan101 no shutdown vrf member Tenant-1 interface Vlan302 description db no shutdown vrf member Tenant-1 ip address 172.16.200.1/24 fabric forwarding mode anycast-gateway interface nve1 no shutdown host-reachability protocol bgp source-interface loopback0 member vni 5502 suppress-arp ingress-replication protocol bgp member vni 900001 associate-vrf interface Ethernet1/1 no switchport ip address 10.10.10.2/30 ip router ospf 10 area 0.0.0.0 no shutdown interface Ethernet1/7 switchport access vlan 302 no shutdown interface loopback0 ip address 2.2.2.2/32 ip router ospf 10 area 0.0.0.0 router ospf 10 router bgp 65535 router-id 2.2.2.2 neighbor 1.1.1.1 remote-as 65535 update-source loopback0 address-family l2vpn evpn send-community send-community extended evpn vni 5502 l2 rd auto route-target import auto route-target export auto Troubleshooting Commands: ------------------------- nexus-sw2# show ip route 172.16.100.100 vrf Tenant-1 IP Route Table for VRF "Tenant-1" '*' denotes best ucast next-hop '**' denotes best mcast next-hop '[x/y]' denotes [preference/metric] '%<string>' in via output denotes VRF <string> 172.16.100.100/32, ubest/mbest: 1/0 *via 1.1.1.1%default, [200/0], 01:50:24, bgp-65535, internal, tag 65535 (evp n) segid: 900001 tunnelid: 0x1010101 encap: VXLAN nexus-sw2# show nve vni Codes: CP - Control Plane DP - Data Plane UC - Unconfigured SA - Suppress ARP SU - Suppress Unknown Unicast Interface VNI Multicast-group State Mode Type [BD/VRF] Flags --------- -------- ----------------- ----- ---- ------------------ ----- nve1 5502 UnicastBGP Up CP L2 [302] SA nve1 900001 n/a Up CP L3 [Tenant-1]
OSPF established:
nexus-sw1# show ip ospf neighbors OSPF Process ID 10 VRF default Total number of neighbors: 1 Neighbor ID Pri State Up Time Address Interface 2.2.2.2 1 FULL/BDR 04:25:56 10.10.10.2 Eth1/1
VLAN 301 VNI is not configured on switch2 but my understanding is you only need to configure the VNIs on the switches where you have hosts connected in that VNI/VLAN.
Any help appreciated.
Solved! Go to Solution.
10-13-2020 02:17 PM
Hello!
Configure this on your Switch 2 :
interface Vlan101 desc L3-VNI no shutdown vrf member Tenant-1 ip forward ----> this command is currently missing and is the cause of the problem (you have it on switch 2).
Without that command - leafs cannot do symmetric IRB .
10-13-2020 02:17 PM
Hello!
10-15-2020 03:56 AM
Hi Horia
Thanks very much, good spot (that was the issue) I did eventually figure it out. I forgot to come back here and post.
Thank you
