Leaf reboots with watchdog-timeout CSCvv04749
tomy.tim
Dear colleagues, I would like to know if anyone has already gone through this problem and if it is necessary to change the equipment because it is a hardware failure. I am currently with an open ticket in TAC, waiting for instructions. I tried to search for information about the BUG without success.
sw-leaf#Show version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_series_home.html
Copyright (c) 2002-2014, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under
license. Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or the GNU
Lesser General Public License (LGPL) Version 2.1. A copy of each
such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://www.opensource.org/licenses/lgpl-2.1.php
Software
BIOS: version 05.39
kickstart: version 14.2(2f) [build 14.2(2f)]
system: version 14.2(2f) [build 14.2(2f)]
PE: version 4.2(2f)
BIOS compile time: 08/30/2019
kickstart image file is: /bootflash/aci-n9000-dk9.14.2.2f.bin
kickstart compile time: 10/29/2019 22:03:15 [10/29/2019 22:03:15]
system image file is: /bootflash/auto-s
system compile time: 10/29/2019 22:03:15 [10/29/2019 22:03:15]
Hardware
cisco N9K-C93180YC-FX ("supervisor")
Intel(R) Xeon(R) CPU D-1528 @ 1.90GHz with 32694272 kB of memory.
Device name: xxxxxxxxx
bootflash: 125029376 kB
Kernel uptime is 01 day(s), 02 hour(s), 17 minute(s), 06 second(s)
Last reset at 852000 usecs after Wed Jan 11 09:45:17 2023 BRST
Reason: watchdog-timeout
System version: 14.2(2f)
Service:plugin
Core Plugin, Ethernet Plugin
Tomy Tim
f00z
Level 3
Level 3
Did you look at the output from 'show logging onboard internal reset-reason' ?
@f00z Yes, I have already done it, I am taking the case with cisco tac and if the failure was hardware, we are monitoring the equipment until the end of the month, it is not a software problem. Thanks for your support
Tomy Tim
