09-24-2021 05:03 AM
What is the length of Nexus 9508 AC power cable CAB-AC-16A-SG-IN? I couldn't find the dimensions in the installation guide. I suspect that it's 2.5m but I can't be sure. If possible please provide a photo/resource.
Thank you!
Lulu
Solved! Go to Solution.
09-24-2021 05:48 AM
Sure you did not find this information, since it was standard i guess - As i used before and remember it approximatly 2Meter (6Ft)
09-24-2021 05:48 AM
09-24-2021 06:35 AM
Hi Balaji Bandi,
Thank you for your answer! If I may follow up, do you know who would be able to provide technical specification for the said cord (Actual photo, electric diagram showing pins)?
09-24-2021 07:42 AM
Not sure, if i am going next time in my DC, will take picture and send, or ask any Cisco Partner can give you that information.
