Maximum Port-Channel Interfaces - N5K C5596UP
luke.brooker1
Hi all,
Looking for some advice, am i interpreting correctly from this document;
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5500/sw/Verified_Scalability/602N12/b_N5500_Verified_Scalability_602N12/b_N5500_Config_Limits_602N11_chapter_01.html
That the maximum number of port-channel interfaces that can be created on a Nexus C5596UP, is 96. And that if i need to create more than this, it will not be possible?
Remi Astruc
Hi Luke,
While the 5596 has "only" 96 physical ports, that is just a mathematical limit. You cannot create more Port-channels than physical ports.
Remi Astruc
With the addition of Cisco Nexus 2000 Series Fabric Extenders, the platform can have many more than 96 interfaces.
oh i found this;
Number of FEX Port Channels/vPCs (across the maximum number of FEXs)
576
1152
So i think im good.
Thanks !
