missing "load-intervall" on SVI interfaces (NXOS)
Good day
I am trying to figure out how i can get more information about traffic going through the SVI on NXOS.
"show interface x and show interface vlan x" on the IOS platfrom show "load-intervall".
This is the same on the NXOS with the "show interface x" but the "show interface vlan x" has no "load-interfall" information.
I am not sure if this is not implemented or i am just missing some obvious way to activate this.
Jaime G.
Hope you are doing well.
From my understanding, the issue you are facing is in regards to the command:
"show interface vlan-id"not displaying "load-interval" as a valid keyword as you attempt to obtain more information about traffic passing through the SVI on your NX-OS device.
In order to better assist you, could you kindly provide the model of the NX-OS device as well as the software version it is running?   Also, it would be helpful to know which modules are installed on the device as there are some limitations to be aware of (please see note below).  To obtain this information, you can run the following commands:
show version
show module
Also, please attempt to run the following command as well on your NX-OS Device to see if we can reach the desired outcome:
show interface vlan-id counters detail all
Note: Finally, I would like to bring up to your attention that if the device we are working with is a Nexus 7K Series using a F2 Line Card Module on Cisco NX-OS Release 6.0, then some software features are not available as per the article below:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/6_x/nx-os/release/notes/61_nx-os_release_note.html#pgfId-608434
More specifically, the following excerpt:
F2 Series I/O modules do not support per-VLAN statistics. Therefore, the show interface command will not display per-VLAN Rx/Tx counters or statistics for switch virtual interfaces (SVIs).
Please feel free to refer to the article for any other information.
i want to thank you for the response Jamie.
We are currently useing 93240YC-FX2 and C93180YC-FX.
We are using NX-OS 9.2(3) and 7.0(3)I7(6).
The
Does not provide the same details as the "load-interval"
Hello again,
Thank you for your reply to my inquiries.
I would like to refer you to the following article:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/6-x/interfaces/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_chapter_0100.html
Following the Load-Interval command guides, you may be able to obtain your desired outcome with monitoring of the SVI's.
Jaime
