Nexus 9000 Access Switch - Interface (Hot standby in bundle)
Hi Team,
We facing issue with one of our nexus 9000 access switch which is showing "(Hot standby in bundle)" error
105 Po105(SD) Eth LACP Eth1/5(H) Eth1/6(H)
106 Po106(SD) Eth LACP Eth1/27(H) Eth1/28(H)
sh int eth1/5
Ethernet1/5 is down (Hot standby in bundle)
sh int eth1/6
Ethernet1/6 is down (Hot standby in bundle)
sh int eth1/27
Ethernet1/27 is down (Hot standby in bundle)
sh int eth1/28
Ethernet1/28 is down (Hot standby in bundle)
interface port-channel105
description F5
switchport mode trunk
spanning-tree port type edge
vpc 105
interface Ethernet1/5
description F5
channel-group 105 mode active
no shutdown
interface Ethernet1/6
description F5
no shutdown
interface port-channel106
description F5
vpc 106
interface Ethernet1/28
description F5
channel-group 106 mode active
no shutdown
interface Ethernet1/27
description F5
no shutdown
The Pair switch everything working fine as expected but switch 02 having issue.
balaji.bandi
here i would check the cables or connected to the right device and right ports ?
BB
