N1k VSM SVS to vCenter drops off/reconnects intermittently,
ray.deasy
I'm having issues with connectivity from my VSM to vCenter. I have active/standby VSM's. Every so often the connection from the VSM to vCenter drops off & later reconnects. The VEM's stay online and the VSM's stay online. There appears to be connectivity issues to the vCenter itself, i'm thinking it may be ssl/cert related but would appreciate a second opinion/advise.
Here are some log output, if someone could help me out as to what the issue may be it would be great.
Ray.
N1KV-PROD-VSM# sh logging last 30
2013 Feb 11 23:57:01 N1KV-PROD-VSM %VMS-3-DVS_UPDATE_ERROR: Unable to Update N1KV DVS in the VM
ware vCenterError: [VMware vCenter Server 5.0.0 build-623373] Operation could not be completed
due to connection failure.Timeout. SSL connect failed in tcp_connect()
2013 Feb 11 23:57:49 N1KV-PROD-VSM %VMS-5-CONN_DISCONNECT: Connection 'PROD-VC' disconnected fr
om the vCenter Server.
2013 Feb 12 00:00:49 N1KV-PROD-VSM %VMS-5-CONN_CONNECT: Connection 'PROD-VC' connected to the v
Center Server.
2013 Feb 12 00:02:09 N1KV-PROD-VSM %VMS-5-CONN_DISCONNECT: Connection 'PROD-VC' disconnected fr
2013 Feb 12 00:05:40 N1KV-PROD-VSM %VMS-5-CONN_CONNECT: Connection 'PROD-VC' connected to the v
Center Server.
2013 Feb 12 00:06:50 N1KV-PROD-VSM %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by admin o
n 157.190.4.113@pts/0
2013 Feb 12 00:07:14 N1KV-PROD-VSM %VMS-3-DVS_UPDATE_ERROR: Unable to Update N1KV DVS in the VM
2013 Feb 12 00:08:12 N1KV-PROD-VSM %VMS-5-CONN_DISCONNECT: Connection 'PROD-VC' disconnected fr
2013 Feb 12 00:11:12 N1KV-PROD-VSM %VMS-5-CONN_CONNECT: Connection 'PROD-VC' connected to the v
Center Server.
2013 Feb 12 00:11:43 N1KV-PROD-VSM %VMS-3-DVS_UPDATE_ERROR: Unable to Update N1KV DVS in the VM
2013 Feb 12 00:13:54 N1KV-PROD-VSM %MSP-5-DOMAIN_CFG_SYNC_DONE: Domain config successfully push
ed to the management server.
2013 Feb 12 00:14:26 N1KV-PROD-VSM %VMS-3-DVS_UPDATE_ERROR: Unable to Update N1KV DVS in the VM
2013 Feb 12 00:14:26 N1KV-PROD-VSM %VMS-3-CONNECTION_ERROR: Unable to communicate with vCenter
Server/ESX. Disconnecting..
2013 Feb 12 00:14:26 N1KV-PROD-VSM %VMS-5-CONN_DISCONNECT: Connection 'PROD-VC' disconnected fr
2013 Feb 12 00:14:26 N1KV-PROD-VSM %MSP-5-PP_UPDATE_FAILED: Update of port-profile 'MGMT_Uplink
' on the vCenter Server failed. Please  verify port-profile config.
2013 Feb 12 00:14:26 N1KV-PROD-VSM %MSP-5-PP_UPDATE_FAILED: Update of port-profile 'Unused_Or_Q
uarantine_Uplink' on the vCenter Server failed. Please  verify port-profile config.
2013 Feb 12 00:14:26 N1KV-PROD-VSM %MSP-5-PP_UPDATE_FAILED: Update of port-profile 'VM_Data_Upl
2013 Feb 12 00:14:26 N1KV-PROD-VSM %MSP-5-PP_UPDATE_FAILED: Update of port-profile 'V_L3_CONTRO
L_99' on the vCenter Server failed. Please  verify port-profile config.
2013 Feb 12 00:14:26 N1KV-PROD-VSM %VMS-5-CONN_CONNECT: Connection 'PROD-VC' connected to the v
Center Server.
2013 Feb 12 00:16:34 N1KV-PROD-VSM %VMS-5-CONN_DISCONNECT: Connection 'PROD-VC' disconnected fr
2013 Feb 12 00:20:24 N1KV-PROD-VSM %VMS-5-CONN_CONNECT: Connection 'PROD-VC' connected to the v
Center Server.
2013 Feb 12 00:21:42 N1KV-PROD-VSM %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by admin o
2013 Feb 12 00:22:49 N1KV-PROD-VSM %VMS-3-DVS_UPDATE_ERROR: Unable to Update N1KV DVS in the VM
due to connection failure.End of file or no input: Operation interrupted or timed out after 160
s send or 160s receive delay.
2013 Feb 12 00:23:40 N1KV-PROD-VSM %VMS-5-CONN_DISCONNECT: Connection 'PROD-VC' disconnected fr
2013 Feb 12 00:23:40 N1KV-PROD-VSM %VMS-5-CONN_CONNECT: Connection 'PROD-VC' connected to the v
Center Server.
2013 Feb 12 00:25:49 N1KV-PROD-VSM %VMS-3-DVS_UPDATE_ERROR: Unable to Update N1KV DVS in the VM
2013 Feb 12 00:25:53 N1KV-PROD-VSM %VMS-5-CONN_DISCONNECT: Connection 'PROD-VC' disconnected fr
2013 Feb 12 00:28:52 N1KV-PROD-VSM %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by admin o
2013 Feb 12 00:28:53 N1KV-PROD-VSM %VMS-5-CONN_CONNECT: Connection 'PROD-VC' connected to the v
Center Server.
2013 Feb 12 00:29:57 N1KV-PROD-VSM %VMS-5-CONN_DISCONNECT: Connection 'PROD-VC' disconnected fr
N1KV-PROD-VSM#
N1KV-PROD-VSM#
N1KV-PROD-VSM# sh vms internal event-history errors
1) Event:E_DEBUG, length:53, at 431472 usecs after Tue Feb 12 00:34:05 2013
    [102] waitForTask(5968): Error in creating Task filter
2) Event:E_DEBUG, length:216, at 431466 usecs after Tue Feb 12 00:34:05 2013
    [102] convert_soap_fault_to_err(1858): SOAP 1.1 fault: SOAP-ENV:Client [VMware vCenter Serv
er 5.0.0 build-623373] Operation could not be completed due to connection failure.Timeout. SSL
3) Event:E_DEBUG, length:49, at 431422 usecs after Tue Feb 12 00:34:05 2013
    [102] createFilter(5838): Error in creating filter
4) Event:E_DEBUG, length:103, at 662124 usecs after Tue Feb 12 00:33:33 2013
    [102] sf_mgmt_srv_lib_update_dvswitch(1434): updating dvs by switch uuid failed. Sending sy
slog message.
5) Event:E_DEBUG, length:83, at 662117 usecs after Tue Feb 12 00:33:33 2013
    [102] updateDVSBySwitchUUID(3907): failed to retrieve dvs info by uuid. returning -1
6) Event:E_DEBUG, length:216, at 662112 usecs after Tue Feb 12 00:33:33 2013
7) Event:E_DEBUG, length:77, at 662090 usecs after Tue Feb 12 00:33:33 2013
    [102] getDVSInfoBySwitchUUID(4200): failed to get object properties. returning
8) Event:E_DEBUG, length:216, at 662076 usecs after Tue Feb 12 00:33:33 2013
9) Event:E_DEBUG, length:57, at 662033 usecs after Tue Feb 12 00:33:33 2013
    [102] getObjectProperties(2344): RetrieveProperties failed
10) Event:E_DEBUG, length:81, at 322004 usecs after Tue Feb 12 00:33:00 2013
    [102] sf_mgmt_srv_get_all_dvpgs(393): dvs = null or no dvpgs exist. returning fail
11) Event:E_DEBUG, length:69, at 321922 usecs after Tue Feb 12 00:33:00 2013
    [102] vms_connect(1837): Failed to remove visibility role (0x41b1000c)
12) Event:E_DEBUG, length:106, at 321805 usecs after Tue Feb 12 00:33:00 2013
    [102] vms_vim_delete_visibility_role(3741): Error occurred while searching for visibility r
ole (0x41b1000c)
13) Event:E_DEBUG, length:104, at 321800 usecs after Tue Feb 12 00:33:00 2013
    [102] convert_soap_fault_to_err(1858): SOAP 1.1 fault: (null) [VMware vCenter Server 5.0.0
build-623373]
14) Event:E_DEBUG, length:216, at 342035 usecs after Tue Feb 12 00:29:57 2013
15) Event:E_DEBUG, length:60, at 342013 usecs after Tue Feb 12 00:29:57 2013
    [102] waitForTask(6001): ERROR in Retreiving taskInfo from VC
16) Event:E_DEBUG, length:216, at 342005 usecs after Tue Feb 12 00:29:57 2013
17) Event:E_DEBUG, length:216, at 341974 usecs after Tue Feb 12 00:29:57 2013
18) Event:E_DEBUG, length:57, at 341923 usecs after Tue Feb 12 00:29:57 2013
19) Event:E_DEBUG, length:216, at 81730 usecs after Tue Feb 12 00:29:25 2013
20) Event:E_DEBUG, length:84, at 81708 usecs after Tue Feb 12 00:29:25 2013
    [102] getDVPortgroupInfo(4280): failed to get object properties for pg mor. returning
21) Event:E_DEBUG, length:216, at 81693 usecs after Tue Feb 12 00:29:25 2013
22) Event:E_DEBUG, length:57, at 81648 usecs after Tue Feb 12 00:29:25 2013
23) Event:E_DEBUG, length:81, at 794658 usecs after Tue Feb 12 00:28:53 2013
24) Event:E_DEBUG, length:103, at 893290 usecs after Tue Feb 12 00:25:49 2013
slog message.
25) Event:E_DEBUG, length:81, at 872872 usecs after Tue Feb 12 00:25:49 2013
    [102] waitForTask(5983): Failed to wait for updates on the Task. UpdateSet is NULL
26) Event:E_DEBUG, length:271, at 872863 usecs after Tue Feb 12 00:25:49 2013
    [102] convert_soap_fault_to_err(1858): Error -1 fault: SOAP-ENV:Client [VMware vCenter Serv
er 5.0.0 build-623373] Operation could not be completed due to connection failure.End of file o
r no input: Operation interrupted or timed out after 160s send or 160s receive delay.
27) Event:E_DEBUG, length:54, at 872795 usecs after Tue Feb 12 00:25:49 2013
    [102] waitForUpdates(5909): ERROR: in WaitForUpdates...
28) Event:E_DEBUG, length:81, at 872468 usecs after Tue Feb 12 00:25:49 2013
    [102] vms_dequeue: (Error) SYSERR_FU_xx: 0x10, err_num (16) in fu_priority_select
29) Event:E_DEBUG, length:81, at 872140 usecs after Tue Feb 12 00:25:49 2013
30) Event:E_DEBUG, length:271, at 869803 usecs after Tue Feb 12 00:24:59 2013
31) Event:E_DEBUG, length:84, at 869779 usecs after Tue Feb 12 00:24:59 2013
32) Event:E_DEBUG, length:271, at 869764 usecs after Tue Feb 12 00:24:59 2013
33) Event:E_DEBUG, length:57, at 869692 usecs after Tue Feb 12 00:24:59 2013
34) Event:E_DEBUG, length:81, at 482043 usecs after Tue Feb 12 00:24:11 2013
35) Event:E_DEBUG, length:69, at 481930 usecs after Tue Feb 12 00:24:11 2013
    [102] vms_connect(1837): Failed to remove visibility role (0x41b1000d)
36) Event:E_DEBUG, length:106, at 481876 usecs after Tue Feb 12 00:24:11 2013
ole (0x41b1000d)
37) Event:E_DEBUG, length:216, at 481870 usecs after Tue Feb 12 00:24:11 2013
38) Event:E_DEBUG, length:216, at 481827 usecs after Tue Feb 12 00:24:11 2013
39) Event:E_DEBUG, length:57, at 481785 usecs after Tue Feb 12 00:24:11 2013
40) Event:E_DEBUG, length:271, at 867776 usecs after Tue Feb 12 00:23:39 2013
41) Event:E_DEBUG, length:60, at 867753 usecs after Tue Feb 12 00:23:39 2013
42) Event:E_DEBUG, length:271, at 867746 usecs after Tue Feb 12 00:23:39 2013
43) Event:E_DEBUG, length:271, at 867713 usecs after Tue Feb 12 00:23:39 2013
44) Event:E_DEBUG, length:57, at 867637 usecs after Tue Feb 12 00:23:39 2013
45) Event:E_DEBUG, length:103, at 865970 usecs after Tue Feb 12 00:22:49 2013
slog message.
46) Event:E_DEBUG, length:271, at 865958 usecs after Tue Feb 12 00:22:49 2013
47) Event:E_DEBUG, length:71, at 865876 usecs after Tue Feb 12 00:22:49 2013
    [102] updateDVSBySwitchUUID(3945): DVSPerformProductSpecOperation failed
48) Event:E_DEBUG, length:271, at 866456 usecs after Tue Feb 12 00:21:59 2013
49) Event:E_DEBUG, length:84, at 866432 usecs after Tue Feb 12 00:21:59 2013
50) Event:E_DEBUG, length:271, at 866418 usecs after Tue Feb 12 00:21:59 2013
51) Event:E_DEBUG, length:57, at 866345 usecs after Tue Feb 12 00:21:59 2013
52) Event:E_DEBUG, length:81, at 694641 usecs after Tue Feb 12 00:20:24 2013
53) Event:E_DEBUG, length:81, at 868900 usecs after Tue Feb 12 00:17:24 2013
54) Event:E_DEBUG, length:81, at 865742 usecs after Tue Feb 12 00:16:34 2013
55) Event:E_DEBUG, length:271, at 872408 usecs after Tue Feb 12 00:15:44 2013
56) Event:E_DEBUG, length:84, at 872390 usecs after Tue Feb 12 00:15:44 2013
57) Event:E_DEBUG, length:271, at 872378 usecs after Tue Feb 12 00:15:44 2013
58) Event:E_DEBUG, length:57, at 872324 usecs after Tue Feb 12 00:15:44 2013
59) Event:E_DEBUG, length:81, at 701396 usecs after Tue Feb 12 00:14:26 2013
60) Event:E_DEBUG, length:69, at 701325 usecs after Tue Feb 12 00:14:26 2013
61) Event:E_DEBUG, length:106, at 701209 usecs after Tue Feb 12 00:14:26 2013
ole (0x41b1000c)
62) Event:E_DEBUG, length:104, at 701205 usecs after Tue Feb 12 00:14:26 2013
build-623373]
63) Event:E_DEBUG, length:86, at 564869 usecs after Tue Feb 12 00:14:26 2013
    [102] vms_ppm_sync_notify_cback(3897): No active connection to vc to update opaque data
64) Event:E_DEBUG, length:103, at 511811 usecs after Tue Feb 12 00:14:26 2013
slog message.
65) Event:E_DEBUG, length:81, at 471724 usecs after Tue Feb 12 00:14:26 2013
66) Event:E_DEBUG, length:216, at 471716 usecs after Tue Feb 12 00:14:26 2013
67) Event:E_DEBUG, length:54, at 471679 usecs after Tue Feb 12 00:14:26 2013
68) Event:E_DEBUG, length:102, at 285651 usecs after Tue Feb 12 00:13:55 2013
    [102] sf_mgmt_srv_updt_port_profile_desc(656): sf_mgmt_srv_lib_updt_dv_port_profile failed.
return fail
69) Event:E_DEBUG, length:226, at 266924 usecs after Tue Feb 12 00:13:55 2013
    [102] populate_err_with_vcinfo(732):  ERROR:  [VMware vCenter Server 5.0.0 build-623373] Ca
nnot set number of ports to 0 because at least 4 out of 4 ports are still in use. A specified p
arameter was not correct.
spec.numPorts.
70) Event:E_DEBUG, length:88, at 266909 usecs after Tue Feb 12 00:13:55 2013
    [102] isTaskComplete(6077):  ERROR: A specified parameter was not correct.
spec.numPorts
71) Event:E_DEBUG, length:104, at 897254 usecs after Tue Feb 12 00:13:04 2013
build-623373]
72) Event:E_DEBUG, length:271, at 841526 usecs after Tue Feb 12 00:13:04 2013
73) Event:E_DEBUG, length:271, at 841496 usecs after Tue Feb 12 00:13:04 2013
74) Event:E_DEBUG, length:57, at 841424 usecs after Tue Feb 12 00:13:04 2013
75) Event:E_DEBUG, length:70, at 751467 usecs after Tue Feb 12 00:12:15 2013
    [102] vms_vim_rename_dvs_folder(3144): RenameDVSFolder operation failed
76) Event:E_DEBUG, length:39, at 751445 usecs after Tue Feb 12 00:12:15 2013
    [102] Rename(2849): Rename Task failed
77) Event:E_DEBUG, length:103, at 651647 usecs after Tue Feb 12 00:11:43 2013
slog message.
78) Event:E_DEBUG, length:83, at 651640 usecs after Tue Feb 12 00:11:43 2013
79) Event:E_DEBUG, length:216, at 651634 usecs after Tue Feb 12 00:11:43 2013
80) Event:E_DEBUG, length:77, at 651612 usecs after Tue Feb 12 00:11:43 2013
81) Event:E_DEBUG, length:216, at 651598 usecs after Tue Feb 12 00:11:43 2013
82) Event:E_DEBUG, length:57, at 651556 usecs after Tue Feb 12 00:11:43 2013
83) Event:E_DEBUG, length:81, at 277011 usecs after Tue Feb 12 00:11:12 2013
84) Event:E_DEBUG, length:69, at 276931 usecs after Tue Feb 12 00:11:12 2013
85) Event:E_DEBUG, length:106, at 276817 usecs after Tue Feb 12 00:11:12 2013
ole (0x41b1000c)
86) Event:E_DEBUG, length:104, at 276813 usecs after Tue Feb 12 00:11:12 2013
build-623373]
87) Event:E_DEBUG, length:70, at 232084 usecs after Tue Feb 12 00:07:46 2013
    [102] performDVSProductSpecOperation(5490): Couldn't retrieve bundleId
88) Event:E_DEBUG, length:65, at 232079 usecs after Tue Feb 12 00:07:46 2013
    [102] getDVSBundleId(5322): coudn't retrieve bundleID. return null
89) Event:E_DEBUG, length:216, at 232068 usecs after Tue Feb 12 00:07:46 2013
90) Event:E_DEBUG, length:57, at 232014 usecs after Tue Feb 12 00:07:46 2013
91) Event:E_DEBUG, length:103, at 521862 usecs after Tue Feb 12 00:07:14 2013
slog message.
92) Event:E_DEBUG, length:83, at 521848 usecs after Tue Feb 12 00:07:14 2013
93) Event:E_DEBUG, length:216, at 521829 usecs after Tue Feb 12 00:07:14 2013
94) Event:E_DEBUG, length:77, at 521807 usecs after Tue Feb 12 00:07:14 2013
95) Event:E_DEBUG, length:216, at 521793 usecs after Tue Feb 12 00:07:14 2013
96) Event:E_DEBUG, length:57, at 521752 usecs after Tue Feb 12 00:07:14 2013
97) Event:E_DEBUG, length:216, at 401892 usecs after Tue Feb 12 00:06:43 2013
98) Event:E_DEBUG, length:84, at 401869 usecs after Tue Feb 12 00:06:43 2013
99) Event:E_DEBUG, length:216, at 401855 usecs after Tue Feb 12 00:06:43 2013
100) Event:E_DEBUG, length:57, at 401812 usecs after Tue Feb 12 00:06:43 2013
101) Event:E_DEBUG, length:81, at 56168 usecs after Tue Feb 12 00:06:12 2013
102) Event:E_DEBUG, length:69, at 55988 usecs after Tue Feb 12 00:06:12 2013
103) Event:E_DEBUG, length:106, at 55827 usecs after Tue Feb 12 00:06:12 2013
ole (0x41b1000c)
104) Event:E_DEBUG, length:104, at 55821 usecs after Tue Feb 12 00:06:12 2013
build-623373]
105) Event:E_DEBUG, length:83, at 962201 usecs after Tue Feb 12 00:06:11 2013
    [102] vms_vim_create_host_filter(2456): Failed to create a filter with the host spec
106) Event:E_DEBUG, length:216, at 962195 usecs after Tue Feb 12 00:06:11 2013
107) Event:E_DEBUG, length:49, at 962148 usecs after Tue Feb 12 00:06:11 2013
108) Event:E_DEBUG, length:81, at 801167 usecs after Tue Feb 12 00:02:09 2013
109) Event:E_DEBUG, length:271, at 799785 usecs after Tue Feb 12 00:02:09 2013
110) Event:E_DEBUG, length:60, at 799762 usecs after Tue Feb 12 00:02:09 2013
111) Event:E_DEBUG, length:271, at 799754 usecs after Tue Feb 12 00:02:09 2013
N1KV-PROD-VSM# sh module
Mod  Ports  Module-Type                       Model               Status
1    0      Virtual Supervisor Module         Nexus1000V          active *
2    0      Virtual Supervisor Module         Nexus1000V          ha-standby
3    248    Virtual Ethernet Module           NA                  ok
4    248    Virtual Ethernet Module           NA                  ok
5    248    Virtual Ethernet Module           NA                  ok
6    248    Virtual Ethernet Module           NA                  ok
Mod  Sw                  Hw
1    4.2(1)SV2(1.1)      0.0
2    4.2(1)SV2(1.1)      0.0
3    4.2(1)SV2(1.1)      VMware ESXi 5.0.0 Releasebuild-474610 (3.0)
4    4.2(1)SV2(1.1)      VMware ESXi 5.0.0 Releasebuild-469512 (3.0)
5    4.2(1)SV2(1.1)      VMware ESXi 5.0.0 Releasebuild-474610 (3.0)
6    4.2(1)SV2(1.1)      VMware ESXi 5.0.0 Releasebuild-474610 (3.0)
N1KV-PROD-VSM# 2013 Feb 12 00:36:34 N1KV-PROD-VSM %VMS-3-DVS_UPDATE_ERROR: Unable to Update N1KV DVS in the VMware vCenterError: [VMware vCenter Server 5.0.0 build-623373] Operation could not be completed due to connection failure.End of file or no input: Operation interrupted or timed out after 160s send or 160s receive delay.
2013 Feb 12 00:36:34 N1KV-PROD-VSM %VMS-3-CONNECTION_ERROR: Unable to communicate with vCenter Server/ESX. Disconnecting..
2013 Feb 12 00:36:34 N1KV-PROD-VSM %VMS-5-CONN_DISCONNECT: Connection 'PROD-VC' disconnected from the vCenter Server.
2013 Feb 12 00:36:35 N1KV-PROD-VSM %MSP-5-PP_UPDATE_FAILED: Update of port-profile 'MGMT_Uplink' on the vCenter Server failed. Please  verify port-profile config.
2013 Feb 12 00:36:35 N1KV-PROD-VSM %MSP-5-PP_UPDATE_FAILED: Update of port-profile 'Unused_Or_Quarantine_Uplink' on the vCenter Server failed. Please  verify port-profile config.
2013 Feb 12 00:36:35 N1KV-PROD-VSM %MSP-5-PP_UPDATE_FAILED: Update of port-profile 'VM_Data_Uplink' on the vCenter Server failed. Please  verify port-profile config.
2013 Feb 12 00:36:35 N1KV-PROD-VSM %MSP-5-PP_UPDATE_FAILED: Update of port-profile 'V_L3_CONTROL_99' on the vCenter Server failed. Please  verify port-profile config.
2013 Feb 12 00:36:35 N1KV-PROD-VSM %VMS-5-CONN_CONNECT: Connection 'PROD-VC' connected to the vCenter Server.
2013 Feb 12 00:37:37 N1KV-PROD-VSM %VMS-3-DVS_UPDATE_ERROR: Unable to Update N1KV DVS in the VMware vCenterError: Error in creating Task filter
N1KV-PROD-VSM#
N1KV-PROD-VSM# 2013 Feb 12 00:38:09 N1KV-PROD-VSM %VMS-5-CONN_DISCONNECT: Connection 'PROD-VC' disconnected from the vCenter Server.
N1KV-PROD-VSM# sh svs connections
connection PROD-VC:
    ip address: 192.168.10.10
    remote port: 80
    protocol: vmware-vim https
    certificate: default
    datacenter name: CIT
    admin:
    max-ports: 8192
    DVS uuid: 57 b5 01 50 b3 f6 66 b4-e1 be a3 2a 97 4a f2 11
    config status: Enabled
    operational status: Disconnected
    sync status: -
    version: -
    vc-uuid: -
N1KV-PROD-VSM# sh svs domain
SVS domain config:
  Domain id:    30
  Control vlan:  NA
  Packet vlan:   NA
  L2/L3 Control mode: L3
  L3 control interface: mgmt0
  Status: Config push to VC successful.
  Control type multicast: No
Note: Control VLAN and Packet VLAN are not used in L3 mode
N1KV-PROD-VSM#
ray.deasy
I got this one sorted, Turned out to be a sub-optimal routing issue between the N1kv MGMT & vCenter affecting the SVS connection. I shutdown one of our  L2/L3 links out from our UCS/N5K systems to an area where vCenter was in production and it stabilised. Just need to fix it now and re-activate the link.
No connection drop off's since this.
Hopefully this may assist someone who sees this type of behaviour in the future,
Ray.
Please provide additional details about the underlying issue and the fix you were able to implement. Thanks.
Hello Raymond,
Can you please help me understand what you mean by "I shutdown one of our  L2/L3 links out from our UCS/N5K systems to an area where vCenter was in production and it stabilised. Just need to fix it now and re-activate the link."
Thank you.
With regards,
Nithin.
admin11111
Level 4
Level 4
I am seeijnt this on VSphere 5.5 and I have no idea how to resolve or troubleshoot.
Any help would be most welcome. Below are the log messages.
