N3K-C3548P-10GX keep rebooted
todd.hsieh
My customer N3K-C3548P-10GX keep rebooted and caused a service disruption about 20 minutes.
We removed this 3548 from the production network. When we did some investigation, we found a successive restart with death reason.
May I know if this is about to hardware or software issue ?
Thank you!
Service: pfma
Description: N5k platform manager Daemon
Executable: /isan/bin/pfm
Started at Wed Nov 9 15:52:47 2016 (608989 us)
Stopped at Thu Mar 9 13:51:13 2023 (763768 us)
Uptime: 2310 days 21 hours 58 minutes 26 seconds
Start type: SRV_OPTION_RESTART_STATELESS (23)
Death reason: SYSMGR_DEATH_REASON_FAILURE_SIGNAL (2)
Last heartbeat 0.79 secs ago
Service: pfma
Started at Thu Mar 9 14:01:56 2023 (512410 us)
Stopped at Thu Mar 9 14:03:36 2023 (752789 us)
Uptime: 1 minutes 40 seconds
Last heartbeat 0.93 secs ago
Lebowski1991
First, let me say that the only appropriate way to get a definitive answer to this issue should be through Cisco TAC as further troubleshooting would require analyzing core dumps and show tech-support which could contain customer sensitive data.
I believe PFM would stand for Power Fabric module and as such it should be related to environment driven event.
I don't have C3500 in my deployment to check however you could try with the following commands to get a bit more of an understanding of the issue:
show environment power detail
Show environment temp detail
show environment fan detail
Show logging nvram
show logging onboard exeption-log
show logging onboard environmental-history
show logging onboard kernel-trace
If however you insist on troubleshooting this with the community rather than with TAC, do share the said logs ( filter out any customer sensitive data) and I can give it a go.
Hopefully this helps!
Lebowski1991
Show logging nvram
Hi  Lebowski1991
Thank you. This is helpful information. I keep these command in memo.
We have sent this N3K back to our supplier who will do the RMA.
