N9K MACSEC and SPAN
Wes Smith
On NX 93240-FX2 devices that use MACSEC on the  40/100 QSFP ports
What does SPAN capture for MACSEC secured ports?   Does it capture the clear-text data or the encrypted stream ?
I have not been able to find any reference.
Thanks in advance
BrianSekleckiGE
Did you ever get a chance to test this? Since the encryption happens in Hardware, presumably after the SPAN process in software replicates the switchport's outbound buffer, I assume you see the cleartext contents?
In which case, you would need a passive optical splitter to observe the encrypted traffic on the wire.
